    Configuring I/O
    This router model has one I/O pin available for analog input or digital input/output configuration:
    • Power connector—Pin 4 (GPIO)
    You can use Pin 4 in conjunction with Telemetry to configure the router to send a report when the I/O pin state changes; for example when a switch is opened or closed. The digital input can also be used with the standby timer. For more information, refer to the Hardware Guide for the router.
    Configuration
    To set the mode for the I/O pin:
    1. Go to System > I/O > Configuration.
    2. Select the Mode. The mode settings available are:
      • Digital Input and Output
      • Analog Input
      • Disabled (default)
      Once the Mode is selected, a corresponding entry will appear in the Analog Inputs table or the Digital Inputs and Digital Outputs tables.
    Analog Inputs
    • Power supply voltage
    • Temperature, weight, volume, flow represented as voltage
    • An incremental gauge with a voltage output
    • Vehicle battery voltage
    In the Analog Inputs Table you can transform the voltage readings to a more convenient unit of measurement. For example, degrees Celsius or Fahrenheit for temperature, liters for volume, etc.
    • Deadband: the minimum change in mV since the last analog I/O value was received that is needed to update the value again.
    • Coefficient: a multiplicative value used in calculating the Transformed Value (displayed in Status > System > I/O)
    • Offset: a value used to compensate the Transformed Value (displayed in Status > System > I/O)
    • Unit (optional): Enter the unit of measurement for the transformed analog value. For example, mV, V, degrees Celsius, kg, L, %, and so on. This entry does not affect any calculations, but it is shown with the Transformed Value in the I/O Status table.
    Step 1: Coefficient and Offset
    0 V is equivalent to –20°C
    30 V is equivalent to 100°C
    a * 0V + b = –20C
    a * 30V + b = 100C
    where:
    a = coefficient
    b = offset
    a * 30V = 120V
    a = 4
    4 * 0V + b = –20
    b = –20
    1. Go to System > I/O > Analog Inputs.
    2. Enter the values for the coefficient and offset. (In this example, the coefficient is 4 and the offset is –20.)
    Digital Inputs
    Digital inputs monitor contact closures on a switch. This allows you to monitor changes such as:
    • When a door or latch is open or closed
    • When a container is full or empty
    • When a switch or valve is opened or closed
    • The level of fuel in a vehicle (connected to an on/off sensor)
    • When the trunk of a vehicle is opened or closed
    The Digital Inputs Table displays:
    • Type: Disabled or In (input)
    • Status: Inactive (false) or Active (true)
    • Active High/Low: options are Active High, Active Low
    • Pull Up: options for the pull-up resistor are On or Off. In some applications, enabling Pull Up ensures that an Active High or Low logic level persists after the digital input signal is received, and thus prevent a circuit from floating.
    Configure Digital Input
    1. Go to System > I/O > Digital Inputs.
    2. In the DIGITAL INPUTS TABLE, select Active High or Active Low.
    3. Enable/disable the Pull Up.
    The power connector GPIO (pin 4) digital input can also be used to put the device into a standby mode and to wake the router up. To configure this, see Configuring Power Settings .
    Digital Outputs
    When Power Connector pin 4 is configured as Digital Input and Output, you can configure the Digital Outputs settings. You can use Digital Output to drive a relay or for other uses where a switchable low-side current sink is required.
    Configure Digital Output
    To enable Digital Output:
    1. Go to System > I/O > Digital Outputs.
    2. In the DIGITAL OUTPUTS TABLE, set Digital Outputs to Pin Grounded.
    I/O Status
    To view the status of the router’s GPIOs, go to Status > System > I/O (or click the link under Configuration).
    The I/O STATUS table shows each enabled I/O Pin and its:
    • Configured Mode
    • Raw Value: voltages in mV for Analog Input or 0/1 for Digital Input/Output
    • Transformed Value: calculated as (Value in units of Volts * Coefficient) + Offset. Allows for conversion of the analog I/O value to meaningful ranges/values where the Transformed Value can then be used in the chosen events reporting output.
    The transformation function uses Raw Value in units of volts, not millivolts, to display the Transformed Value.
    Data sampling is taken over 20 measurements during a 250 ms interval. The measurements are averaged to generate a sample. If the sample has changed by the amount of the Deadband or a time period of 2.5 minutes has passed, then the Raw Value is updated.
    GPIO Reporting
