    Configuring Wi-Fi
    This page shows you how to configure Wi-Fi for your AirLink RX55 router in Access Point mode and Client mode.
    Wi-Fi Interfaces
    • Wi-Fi A
    • Wi-Fi B
    Each interface is configurable as Access Point (2.4GHZ or 5GHz) or Client (2.4GHz, 5GHz, or 2.4GHz + 5GHz).
    REGION
    The REGION field is the regulatory domain that the router Wi-Fi is using. It is determined by using either the Global Navigation Satellite System (GNSS) sensors in the router, or by the Mobile Country Code (MCC) or Mobile Network Code (MNC) received from the carrier and received directly by the receiver on the device. The router automatically loads the operating frequencies for that regulatory region on each Wi-Fi radio interface in the software and enables 802.11d for broadcasting the newly obtained country information. If the router is not able to determine the region, it uses a default region setting. For more information on supported channels, please refer to the Wi-Fi specifications in the AirLink RX55 Hardware User Guide .
    PLACEMENT
    • When Indoor is selected, the router can use only the channels allowed for indoor use.
    For more information on supported channels, refer to the Wi-Fi specifications in the AirLink RX55 Hardware User Guide .
    If the AirLink router cannot determine the region, the default region setting for that router variant determines whether the PLACEMENT switch appears.
    For example, if an AirLink router EMEA variant cannot determine the region, the REGION appears as “Unknown (restricted)” and the PLACEMENT switch appears, with Indoor as the default.
    NOTES:
    • Enabling DFS Channels will make DFS-specific channels available to both AP and Client mode regardless of the region and, if applicable, PLACEMENT option.
    For details on how your router is determining its region, go to Status > Services > Geolocation.
    To configure an interface as an Access Point, click at the end of a row for Wi-Fi A or Wi-Fi B in the WI-FI INTERFACES table (as shown above).
    • ENABLE the interface.
    • Select the MODE — Access Point in this case.
      Best Practice recommendation: If 2.4GHz and 5GHz APs are configured on different LAN segments, use different SSIDs and security passphrases to make sure DHCP renews IP addresses when switching between the APs.
      • WPA — Requires only a SECURITY PASSPHRASE (This mode is not recommended and will only be seen if the LEGACY MODE is enabled.)
      • Select the RADIUS AUTHENTICATION SERVER (PRIMARY)*. The primary RADIUS server is required. If there are no servers in the list, select **CREATE and enter the following:
        • LABEL — name of the server
        • TIMEOUT — the time limit for the server to respond. If the server does not respond during the timeout, the authentication fails and the other RADIUS AUTHENTICATION SERVER (if configured) checks the credentials.
        • SECRET — the shared secret used for encryption when a client connected to the device’s AP is connecting to the RADIUS authentication server.
      • Select the optional RADIUS AUTHENTICATION SERVER (SECONDARY) to specify the backup RADIUS server. Select from the list, or select CREATE.
    • For the RX55 and XR60, both RADIUS authentication servers must have the same shared secret.
      • Disabled
    • Enable DFS CHANNELS to open up more Wi-Fi channels for the router to use, while preventing the router interfering with channels used by radar equipment (near airports, for example). With DFS CHANNELS enabled, the router will switch channels if it detects radar equipment using the same channel. Unless you know that your other operating equipment is DFS capable, Sierra Wireless recommends leaving DFS CHANNELS disabled.
      • For passenger Wi-Fi applications, enable client isolation to enhance security.
      • Disable client isolation if you have client applications on the same LAN segment that need to interact with each other.
    • Set the MAX NUMBER OF CLIENTS — Enter the maximum number of clients that can connect simultaneously to this access point interface. As a guideline, set a limit that is slightly higher than the number of clients you expect to connect. The default is 10, with a range of 1 to 10.
      • Disabled (default)
      • Manual — MSS is clamped to the specified maximum value bidirectionally for all inbound (remote-to-LAN) and outbound (LAN-to-remote) TCP connections when the TCP session is established using the Wi-Fi interface.
    • Select the CPU BINDING — This determines which interface the router’s operating system processes first when network packets arrive at Wi-Fi at the same time as other non-Wi-Fi interfaces. By default, no interface is favored; that is, processed first. Semtech recommends leaving CPU BINDING at default unless you are concerned about maximizing Ethernet or Cellular throughput when combined with Wi-Fi traffic. The options are:
      • Default - Favor Neither (default)
      • Favor Ethernet over Wi-Fi — This setting may affect Cellular throughput performance
      • Favor Cellular over Wi-Fi — This setting may affect Ethernet throughput performance
    To configure this feature:
    On Status > Dashboard, the LAN dashboard shows you the Wi-Fi LAN interfaces and the LAN segments they use. A blue Access Point icon ( ) indicates the interface is enabled and operating.
    Additionally, you can go to Status > System > Wi-Fi to view detailed Wi-Fi Access Point status, including the active channel and connected stations (clients).
    Configuring Wi-Fi Client Mode
    To use a scanned SSID:
    1. In the SCANNED SSIDS table, click + to add the desired SSID to the SELECTED SSIDS table.
      Note: The router supports up to 10 SSIDs in the SELECTED SSIDS table.
    2. In Edit SSID, add the credentials required by the SSID’s security mode, along with any other optional settings.
    3. Click UPDATE.
    To create an SSID manually:
    2. Note: The router supports up to 10 SSIDs in the SELECTED SSIDS table.
    3. In the Create SSID screen, enter the SSID name.
    4. Select the SECURITY MODE — Depending on the mode selected, specific security credential types are required:
    5. For all security modes except OPEN and WPA2-Enterprise, enter a SECURITY PASSPHRASE of at least 8 characters.
    6. For WPA2-Enterprise security mode only:
          • USER PASSWORD
            SETTING DESCRIPTION
            TYPE Root Certificate
        • TLS — when selected, requires the following
            SETTING DESCRIPTION
            TYPE Certificate
    5. Select CREATE.
    • Leave the MODE as Client.
      • When you have multiple SSIDs configured, Semtech recommends leaving SSID SELECTION at the default Auto (Highest Priority) setting. The router will automatically search and connect to an SSID depending on priority. If priorities are identical, the router will use the closest SSID with the fastest estimated link speed.
      • To configure the Wi-Fi client to use only a single, specific SSID, set SSID SELECTION to Manual and then choose the CONFIGURED SSID to which the router will connect.
      • You can also click CREATE to create a new SSID manually.
    On Status > Dashboard, the WAN dashboard shows you the Wi-Fi WAN interfaces. A grey Wi-Fi icon ( ) indicates a disconnected interface. A blue Wi-Fi icon ( ) indicates a connected interface.
    Additionally, you can go to Status > System > Wi-Fi to view detailed Wi-Fi Client status, including bit rate and the active channel.
