    The AirLink router is equipped with one 10/100/1000 Ethernet (RJ45) port that can be enabled or disabled as needed. When the port is disabled, a connected device cannot connect via Ethernet, and ARP queries do not receive responses on the port.
    Configuring the Ethernet interface
    To configure an Ethernet interface:
    1. Go to Hardware Intefaces > Ethernet interfaces > Configuration.
    2. ENABLE or disable the interface.
    3. Configure WAN AUTO DETECT. When WAN AUTO DETECT is enabled (the default setting), the router attempts to determine if a DHCP server is present on the Ethernet network. If a DHCP server is found, the router obtains an IP address and enters WAN mode. If no DHCP server is found, the port is placed in the Default-LAN Segment.
      For more information, see this Customer Community article.
      When deploying the router, Semtech recommends that WAN AUTO DETECT be disabled, and that the Ethernet ports are manually configured for LAN or WAN.
        • WAN mode, by leaving the LAN segment field empty. When the port is in WAN mode, you can select the port’s IP assignment method (DHCP [default], static, or none) under Networking > General > WAN.
      • When WAN AUTO DETECT is enabled for an Ethernet port, the system may internally modify the DHCP settings for that port. If you disable WAN AUTO DETECT on that same Ethernet port, you should verify the WAN configuration settings (under Networking > General > WAN) and modify them if required.
    4. Select the LAN SEGMENT. When the interface is in LAN mode, you can select (or create) a LAN segment for the interface. Selecting a LAN segment is disabled when WAN AUTO DETECT is enabled; if a DHCP server is not found, the port is put into the Default-LAN by default. For more information on LAN segments, see Configuring LAN Segments.
    5. Set MTU, if required. When the interface is part of a LAN Segment, MTU is set to Auto. When in WAN mode, you can manually configure the MTU as directed by your service provider if you have packet loss due to network fragmentation issues.
    6. Set the LINK MODE, if required. LINK MODE configures the Ethernet port speed and duplex setting. The default setting enables the device you are connecting to, to automatically negotiate the speed and duplex setting with the AirLink router. However, if the connected device has a fixed setting, use this field to change the AirLink router setting to match that of the connected device. You may also lower the link speed to reduce power consumption for applications where the router runs from battery power, or to be compatible with devices that do not support auto negotiation.
    7. Set MSS CLAMPING. MSS (Maximum TCP Segment Size) Clamping controls the maximum packet size used for TCP connections between a local (LAN-side) host and a remote host over the Ethernet WAN interface. MSS Clamping helps avoid possible issues with sending and receiving large TCP packets over the WAN interface when other standard MTU mechanisms do not appear to be working with your installation. The options are:
      • Disabled (default)
      • Auto — When set to Auto, the MSS is calculated based on the detected MTU (Maximum Transmission Unit) of the network path as discovered by Path MTU Discovery (PMTUD).
      • Manual — MSS is clamped to the specified maximum value bi-directionally for all inbound (remote-to-LAN) and outbound (LAN-to-remote) TCP connections when the TCP session is established using the Ethernet interface.
    8. Set MSS. When MSS CLAMPING is set to Manual, set the Maximum TCP Segment Size.
    • Enable or disable the interface
    • Add the Ethernet interface to a LAN Segment (if WAN AUTO DETECT is off for that interface).
    You can configure the Ethernet interface for WAN mode by leaving the LAN Segment field empty.
