| REPORT MODE |
Report that will be generated when the device powers off. Note: Only one report can be selected, and in situations where there is an abrupt power disconnect a report may not be generated. |
| AT EVERY SAMPLE OF… |
GPIO Input Cumulative is calculated using the following:
Example 2: WAN Ready
No sample is generated because the WAN connectivity for the device is still UP through Cellular.
Example 3: Ignition Status
Example 4: Primary WAN
Options are:
Options are:
| <RELATIONAL OPERATOR> |
Options are:
Example : LEVEL Trigger
Options are:
Options are:
Example: EDGE Trigger
| ENABLE | Enables vehicle behavior reports | On/Off | On |
| REPORT MODE | Destination of where reports will be sent to. The MQTT configuration will only display if the REPORT MODE is set to an MQTT option. |
ALMS |
| EXCESSIVE ACCELERATION THRESHOLD(MILLIG) | Maximum acceleration allowed before notification is triggered | 100 to 1000 | 250 |
| EXCESSIVE ACCELERATION QUALIFICATION TIME | Length of time, in milliseconds, over which acceleration data is collected and analyzed to determine whether an excessive acceleration event has occurred | 250 to 1000 | 500 |
| EXCESSIVE BRAKING THRESHOLD(MILLIG) | Maximum braking allowed before notification is triggered | 100 to 1000 | 350 |
| EXCESSIVE BRAKING QUALIFICATION TIME | Length of time, in milliseconds, over which braking data is collected and analyzed to determine whether an excessive braking event has occurred | 250 to 1000 | 500 |
| EXCESSIVE CORNERING THRESHOLD(MILLIG) | Maximum cornering allowed before notification is triggered | 100 to 1000 | 350 |
| EXCESSIVE CORNERING QUALIFICATION TIME | Length of time, in milliseconds, over which cornering data is collected and analyzed to determine whether an excessive cornering event has occurred | 250 to 1000 | 500 |
| SUM THRESHOLD(MILLIG) | Vector sum of 3 dimensions (forward/backward, left/right, up/down) | 100 to 2000 | 800 |
| SUM QUALIFICATION TIME | Amount of time, in milliseconds, that harsh movement was detected. | 250 to 1000 | 250 |
The MQTT section appears only when a custom report or a vehicle behavior report has the REPORT MODE set to an MQTT option.
N/A | N/A |
None |
| TOPIC |
6Q1099009902AC24/test {
“atp.ser” :
“t”: 1693258321.3640001,
“v” : “6Q1099009902AC24”
“ts” : 1693268920.464
0 |
ATP FORMAT |
Individual Timestamp |
| CONNECTION SECURITY |
None |
| ROOT CERTIFICATE |
N/A |
