    Configuring Telemetry
    Telemetry data collection requires the router to be properly installed and connected to the vehicle. For most applications, you must connect the router’s ignition line (white wire on the power connector) to the vehicle ignition, and connect the router to the vehicle bus as described in the XR Series Hardware User Guide.
    General
    Vehicle Settings
    DATA COLLECTION Enables or disables data collection On/Off On
    MODE OF OPERATION Configures when data collection will be active
    • Active always (Ignition status ignored)
    • Active when Ignition is ON
    VEHICLE IGNITION WIRING This setting determines which input line the router monitors for ignition status. Select the option that matches how the vehicle ignition line has been connected to the router.
    VEHICLE IGNITION STATUS Current vehicle ignition status. Read only. On/Off N/A
    Vehicle Odometer
    SET DERIVED ODOMETER (KM) Sets the derived odometer with a starting value from which to calculate further distance from. 0 to 1000000 0
    ENTERED AT Date and time that the SET DERIVED ODOMETER was updated. Read only. N/A N/A
    CURRENT ODOMETER (KM) Current physical odometer reading. Read only. N/A N/A
    CURRENT ODOMETER TIMESTAMP Date and time that the CURRENT ODOMETER was read. Read only. N/A N/A
    Telemetry Status
    To view the status of your telemetry configuration, go to Status/Monitoring > Services > Telemetry.
    J1939 and J1979 protocols are currently supported. Semtech is investigating support for J1979-2 and J1979-3 and VDV 238 protocols. AirLink OS can currently detect both J1979 and J1979-2, but as shown below, Telemetry status will indicate whether a protocol version is not supported.
    AMR Reports
    The complete telemetry data set can be sent to AirVantage allowing for the viewing of all Advanced Mobility Reports (AMR). For more information, see Enabling Reporting in AirLink OS.
    ENABLE When enabled, the full telemetry data set is sent to AirVantage so that all Advanced Mobility Reports (AMR) can be viewed. Only displays when Telemetry is enabled. On/Off On
    Custom Reports
    REPORTS
    SETTING DESCRIPTION
    REPORT MODE
    • ALMS
    • MQTT
    • ALMS and MQTT
    GENERATE THIS REPORT AT POWER ON
    Report that will be generated when the device powers on.
    Note: Only one report can be selected.
    GENERATE THIS REPORT AT POWER OFF
    Report that will be generated when the device powers off.
    Note: Only one report can be selected, and in situations where there is an abrupt power disconnect a report may not be generated.
    SETTING DESCRIPTION
    EVERY… (SECONDS) Number of seconds between each report interval
    SETTING DESCRIPTION
    AT EVERY SAMPLE OF…
    Options are:
    • Ethernet 1 WAN Status
    • Ethernet 2 WAN Status
    • Ethernet 3 WAN Status
    • Ethernet XP WAN Status
    • GPIO Input Cumulative
    • HPUE Ethernet 1 Present
    • HPUE Ethernet 1 Status
    • HPUE Ethernet 2 Present
    • HPUE Ethernet 2 Status
    • HPUE Ethernet 3 Present
    • HPUE Ethernet 3 Status
    • HPUE Ethernet XP Present
    • HPUE Ethernet XP Status
    • Ignition Status
    • Internal Cell Status
    • LPWA Status
    • Primary WAN
    • Primary WAN IPv4
    • Primary WAN IPv6
    • WAN Status
    • Wi-Fi Client 2.4 GHz Status
    • Wi-Fi Client 5 GHz Status
    • XP Cell Status
    GPIO Input Cumulative is calculated using the following:
    • Primary GPIO Input
    • GPIO Input 2
    • GPIO Input 3
    • GPIO Input 4
    • GPIO Input 5
    Example 2: WAN Ready
    • Time A: Cellular is UP. XP Cellular is UP.
    • Time B: Cellular is UP. XP Cellular is DOWN.
    No sample is generated because the WAN connectivity for the device is still UP through Cellular.
    • Time B: Cellular is DOWN. XP Cellular is DOWN.
    Example 3: Ignition Status
    • Time A: Ignition is DOWN.
    • Time B: Ignition is UP.
    • Time C: Ignition is DOWN.
    Example 4: Primary WAN
    • Time A: Cellular is UP and designated PRIMARY WAN. XP Cellular is also UP.
    • Time B: Cellular goes down. The PRIMARY WAN designation is re-evaluated to see if Cellular is still the PRIMARY WAN, and it is not. Cellular – Down. XP Cellular – New PRIMARY WAN.
    SETTING DESCRIPTION
    Options are:
    • Absolute Throttle Position (%)
    • Ambient Air Temp (degrees C)
    • Battery Voltage (V)
    • Calc Engine Load (%)
    • Distance Traveled with MIL on (km)
    • Driver Seatbelt
    • Engine Coolant Temp (degrees C)
    • Engine Fuel Rate (mL/h)
    • Engine Oil Temp (degrees C)
    • Engine RPM
    • Fuel Level input (%)
    • GNSS DR Calibration
    • GNSS Heading (degrees)
    • GNSS Trip Odometer (m)
    • GPIO Input 2
    • GPIO Input 3
    • GPIO Input 4
    • GPIO Input 5
    • Hybrid/EV battery - remaining charge (%)
    • Ignition Status
    • LPWA Status
    • MAF Sensor air flow rate (mg/s)
    • Manifold Surface Temp (degrees C)
    • Odometer (km)
    • PTO Status
    • Run time since DTCs cleared (minutes)
    • Run time with MIL on (minutes)
    • Time since Engine Start (seconds)
    • Transmission Fluid Temp (degrees C)
    • Trip Fuel (liters)
    • Trip Odometer (km)
    • Vehicle Speed (km/h)
    • WAN Status
    • XP Cell Status
    SETTING DESCRIPTION
    Options are:
    • Driver Seatbelt
    • Engine RPM
    • GPIO Input 2
    • GPIO Input 3
    • GPIO Input 4
    • GPIO Input 5
    • Ignition Status
    • LPWA Status
    • Odometer (km)
    • PTO Status
    • WAN Status
    • XP Cell Status
    <RELATIONAL OPERATOR>
    Options are:
    • > (greater than)
    • >= (greater than or equal)
    • == (equal)
    • <= (less than or equal)
    • < (less than)
    • != (not equal)
    Example : LEVEL Trigger
    SETTING DESCRIPTION
    Options are:
    • Driver Seatbelt
    • Engine RPM
    • GPIO Input 2
    • GPIO Input 3
    • GPIO Input 4
    • GPIO Input 5
    • Ignition Status
    • LPWA Status
    • Odometer (km)
    • PTO Status
    • WAN Status
    • XP Cell Status
    Options are:
    • > (greater than)
    • == (equal)
    • < (less than)
    • != (not equal)
    Example: EDGE Trigger
    Vehicle Behavior Reports
    ENABLE Enables vehicle behavior reports On/Off On
    REPORT MODE Destination of where reports will be sent to. The MQTT configuration will only display if the REPORT MODE is set to an MQTT option.
    • ALMS
    • MQTT
    • ALMS and MQTT
    ALMS
    EXCESSIVE ACCELERATION THRESHOLD(MILLIG) Maximum acceleration allowed before notification is triggered 100 to 1000 250
    EXCESSIVE ACCELERATION QUALIFICATION TIME Length of time, in milliseconds, over which acceleration data is collected and analyzed to determine whether an excessive acceleration event has occurred 250 to 1000 500
    EXCESSIVE BRAKING THRESHOLD(MILLIG) Maximum braking allowed before notification is triggered 100 to 1000 350
    EXCESSIVE BRAKING QUALIFICATION TIME Length of time, in milliseconds, over which braking data is collected and analyzed to determine whether an excessive braking event has occurred 250 to 1000 500
    EXCESSIVE CORNERING THRESHOLD(MILLIG) Maximum cornering allowed before notification is triggered 100 to 1000 350
    EXCESSIVE CORNERING QUALIFICATION TIME Length of time, in milliseconds, over which cornering data is collected and analyzed to determine whether an excessive cornering event has occurred 250 to 1000 500
    SUM THRESHOLD(MILLIG) Vector sum of 3 dimensions (forward/backward, left/right, up/down) 100 to 2000 800
    SUM QUALIFICATION TIME Amount of time, in milliseconds, that harsh movement was detected. 250 to 1000 250
    MQTT
    The MQTT section appears only when a custom report or a vehicle behavior report has the REPORT MODE set to an MQTT option.
    AUTO GENERATE CLIENT ID Enables the router’s serial number to be used as the client ID. Enable AUTO GENERATE CLIENT ID if your MQTT broker configuration rejects connections with an empty client ID. You can enable and add this setting to a template and apply it to your fleet instead of configuring a unique client ID for every router. Enabled, Disabled Disabled
    CLIENT ID/ GENERATED CLIENT ID
    Enter a unique MQTT client ID for the router, if required by the MQTT broker. Leave blank for the MQTT broker to assign a client ID.
    When AUTO GENERATE CLIENT ID is enabled, the router serial number is displayed as the GENERATED CLIENT ID.
    N/A N/A
    • None
    • Username and Password
    None
    TOPIC
    6Q1099009902AC24/test {
      “atp.ser” :
            “t”: 1693258321.3640001,
            “v” : “6Q1099009902AC24”
            “ts” : 1693268920.464
    • 0: At most one-time delivery. Your data can be lost. No re-transmission outside of TCP.
    • 1: At least one-time delivery. Your data will be re-transmitted if needed. The message can be received more than once.
    • 2: Exactly one-time delivery. The message will be delivered exactly once but the communication overhead is high (multiple acknowledgement messages).
    0
    • ATP FORMAT: ATP FORMAT will use an atp prefix on the data sent to the MQTT broker; for example: atp.GLON
    • NON-ATP FORMAT: Uses the least amount of data over the air; for example: GLON
    ATP FORMAT
    • Individual Timestamp: Timestamp of each sample collected.
    • Report Timestamp: Timestamp of when the report is generated. Least amount of data used.
    CONNECTION SECURITY
    Sets how the security of the MQTT connection is handled.
    AirLink OS supports TLS encryption for MQTT traffic.
    • None
    • Use TLS with Trusted Third-Party CA: Select this when the MQTT broker is using a certificate from a trusted third party certificate authority. The router will search for the root certificate in its internal root certificate store.
    • Use TLS with Custom CA: Select this when the MQTT broker is using a certificate from a self-signed certificate authority. You will need to add a root certificate under ROOT CERTIFICATE (see below).
    None
    ROOT CERTIFICATE
    Any existing root certificate
    N/A
