    Enabling Reporting in AirLink OS
    AirLink XR80 and XR90 routers, with their vehicle telemetry capability and inertial sensors, will support all features of AMR.
    1. Under Services > Location > General, ensure that GNSS is enabled.
    2. Under Services > Telemetry > General, enable SERVICE.
    3. Under Services > Telemetry > Vehicle:
      • Enable DATA COLLECTION.
      • Set MODE OF OPERATION to Active when Ignition is ON.
      • Set VEHICLE IGNITION WIRING to Connected to AirLink gateway Ignition Sense input line.
    4. Under Services > Telemetry > AMR Reports, enable AMR Reports.
    5. Under System > Power Management > Standby Mode, configure the Ignition Sense Shutdown Delay to be at least 30 seconds.
      • In the TRIGGERS table, click Edit ( ) on the row for Source > Ignition Sense.
      • Set the SHUTDOWN DELAY to at least 30 seconds.
      • Click UPDATE.
