    Radio Module Firmware Image Management
    The installed radio module firmware shown below may vary with your router model and region.
    Automatic Radio Module Firmware Image Switching (Based on Carrier SIM)
    1. Ensure the router is powered off.
    2. Insert the carrier SIM that you want to image switch to into the desired SIM Card (slot).
      • By default on the XR80, SIM Card (slot) 1 maps to the internal radio module and slot 2 maps to the optional XP cartridge.
    3. Power the router on.
    4. Log in to AirLink OS.
    5. Go to System > Admin > Radio Module Image Management.
    6. Check if the required RMFW is showing in the Radio Module Firmware list.
      • If the firmware is showing and the FIRMWARE VERSION is filled in, then it will automatically switch to the correct RMFW when SIM switching.
      • If the firmware is showing, but the FIRMWARE VERSION is blank, then continue with step 7.
      • If the required firmware is not shown, then you must load it manually on the router. See Manually Loading the Radio Module Firmware Image.
    7. Update AirLink OS or re-execute the Airlink OS update even if it is already updated, as described in Updating Airlink OS Software. The software update will take 1–2 minutes, as indicated by the yellow LED chase pattern. During the update, any specified RMFW images not on the router are loaded onto the router, but are not applied to the radio module yet. The router reboots when the software update is complete. After reboot, the router executes several checks and the RMFW image switch occurs based on the SIM that was inserted in Step 2 above, as indicated by the green LED chase pattern. The update should take 2–5 minutes, depending on the RMFW version it is updating to.
    When the update is complete, you can confirm the RMFW configuration under Status > System > Cellular. Check that the FIRMWARE NAME, FIRMWARE VERSION, and FIRMWARE CONFIGURATION have been updated.
    In the above example,
    • If a SIM with PLMN 20801 or 20820 is detected, the system will use BELL RMFW.
    • If a SIM with an ICCID starting with “89330121313814” is detected, TELSTRA RMFW will be used.
    1. Click CREATE.
    2. Click on the entry line to select the desired module/carrier combination from the list.
      If you don’t find your desired radio module/carrier combination in the list:
        a. Click on the entry line and click CREATE.
        b. Enter the new firmware name (Model ID / Firmware Name)
        c. Click CREATE to create an instance with this value.
    3. Click CREATE to add a radio module firmware entry in the table.
    4. Click SAVE and a new row for the selected carrier appears. The FIRMWARE CONFIGURATION and FIRMWARE VERSION fields are blank.
    5. Reboot the router, which will perform an Airlink OS update that will retrieve the RMFW and add it to the router. After reboot, the router executes several checks and the RMFW image switch occurs based on the SIM that was inserted, as indicated by the green LED chase pattern. The update should take 2–5 minutes, depending on the RMFW version it is updating to.
    Optional: Manual Radio Module Firmware Image Switching
    When RADIO FIRMWARE SWITCHING setting is set to Manual, you can manually switch the radio module firmware to a specific network operator using this process. You can check the RADIO FIRMWARE SWITCHING setting in the Hardware Interfaces > Cellular Interfaces > Configuration section.
    As a prerequisite, the RMFW image must be loaded on the router. See Manually Loading the RMFW Image.
    4. Go to Hardware Interfaces > Cellular Interfaces > Configuration.
    5. Under RADIO FIRMWARE SWITCHING, click Automatic to switch it to Manual.
    6. Under SELECT RADIO FIRMWARE, select your desired carrier.
    7. Click SAVE.
    The Cellular ADAPTER STATUS indicates Initializing and then Updating Firmware within a few seconds, as indicated by the green LED chase pattern. The update should take 2–5 minutes depending on the RMFW version it is updating to.
    LPWA Manual Install
    This feature allows you to manually install LPWA radio module firmware. If the Current and Available firmware versions or configurations do not match, or if the router is experiencing LPWA connectivity issues, please contact AirLink Support for assistance before using this feature.
    Use this feature only under guidance from the AirLink Support team. Installing an incompatible firmware or configuration may impact LPWA connectivity.
    Radio Module Firmware Versions
    EM7690
    CARRIER RMFW VERSION
    AT&T/FirstNet 03.14.10.04
    Bell 03.14.10.01
    Generic 03.14.10.04
    Rogers 03.14.10.01
    Telstra 03.10.07.00
    Telus 03.14.10.00
    T-Mobile 03.14.10.01
    Verizon 03.17.04.00
    EM9190
    Bell 03.14.10.01
    Generic 03.17.04.00
    Rogers 03.14.10.01
    Telstra 03.10.07.00
    Telus 03.14.10.00
    Verizon 03.17.04.00
    Softbank1 03.17.04.00
    KDDI1 03.17.04.00
    DOCOMO1 03.17.04.00
    1Non-Wi-Fi models only
    EM9293
    AT&T/FirstNet 02.15.01.00
    Bell 02.17.08.00
    Generic 03.04.10.01
    Rogers 02.17.08.00
    Telstra 02.17.08.00
    Telus 02.17.08.00
    T-Mobile 02.15.01.00
    Verizon 02.17.08.00
    HL7800
    Generic 4.7.1.4
