LPWA Configuration
Sierra Wireless recommends leaving LPWA settings at default. They are pre-configured for the Sierra Wireless R2C eSIM.
Enable
MEDIA STATUS
ADAPTER STATUS
APN IN USE: The APN in use for the current mobile network connection.
NETWORK OPERATOR SWITCHING: By default, the router automatically selects the network operator. To force the router to use a specific network operator, click NETWORK OPERATOR SWITCHING to select Manual, and then select a Network Operator from the list.
ACTIVE NETWORK OPERATOR
SIM CONFIGURATION NAME: By default, the LPWA SIM and associated configuration are included in the SIM Database. You can enter a name for the SIM Configuration in this field. The name appears in the SIM Database.
IPV4: Turn On to allow the mobile network to assign the router an IPv4 address. Turn Off to disable IPv4.
IPv6: NOTE: IPv6 is not available for LPWA. Turn On to allow the mobile network to assign the router an IPv6 address. The IPv6 address and routing information are passed to the LAN clients so that they can acquire IPv6 addresses and pass IPv6 traffic over the mobile network. Turn Off to disable IPv6.
APN MODE: Selects how the router acquires an APN. By default the LPWA interface is in Auto mode, and connects to the Sierra Wireless APN at lp.fota.swir. Select Manual to enter a custom APN (the MANUAL APN field appears in Manual mode).
AUTO MTU: By default, AUTO MTU is On. You can turn AUTO MTU off and manually configure MTU (Maximum Transmission Unit in bytes) if you have VPN issues, and as directed by your service provider.
DATA ROAMING: Enables or disables roaming on the active SIM. When OFF, the active SIM does not use data when roaming.
PREFERRED TECHNOLOGY: Restrict the router to using a specific cellular technology: Auto (default), 3G Only, 4G Only, 5G Only
<!— Remove 5G for 3.0 —>
ENABLE
MEDIA STATUS
ADAPTER STATUS
APN IN USE
NETWORK OPERATOR SWITCHING: By default, the router automatically selects the network operator. To force the router to use a specific network operator, change NETWORK OPERATOR SWITCHING to Manual, and then select a Network Operator from the list.
Automatic: When the router powers on or reboots, it automatically selects and uses the appropriate radio module firmware for the active SIM card. (default)
Manual:The router does not automatically select the appropriate radio module firmware when it is powered on or rebooted. You must select the Network Operator.
SIM CONFIGURATION NAME: By default, the XP1 and XP2 SIMs and associated configuration are included in the SIM Database. You can enter a name for the SIM Configuration in this field. The name appears in the SIM Database.
IPv6: Turn On to allow the mobile network to assign the router an IPv6 address. The IPv6 address and routing information are passed to the LAN clients so that they can acquire IPv6 addresses and pass IPv6 traffic over the mobile network. Turn Off to disable IPv6.
APN MODE: Auto, Manual, Multi
When APN MODE is set to Manual, set the following:
MANUAL APN
AUTHENTICATION PROTOCOL: None, PAP, CHAP, AUTO
AUTHENTICATION USERNAME
AUTHENTICATION PASSWORD
Multi-APN Configuration
Under APN MODE, select Multi.
In the APN List, click CREATE. The Create New Virtual APN configuration screen appears.
Configure the APN settings and then click CREATE.
In the example below, the default cellular interface XP1 has sub-interfaces XP1-1 and XP1-2. These additional APNs are the potentially active interfaces.
