ALEOS AF API Reference Guide 1.3
  • Jul 1, 2016
This provides detailed API documentation of all the Lua modules in ALEOS AF.
Those are the Lua APIs provided by ALEOS AF.
Notes:
  • SSL APIs are available starting 4.4.4 for legacy devices, and starting 4.6.0/4.7.0 for current devices.
  • utils.table.cache API is available starting 4.6.1 release.
Module
airvantage
Provides interfaces with the M2M Cloud Services Platform.
airvantage.asset
Racon Application Services object used to send data to the M2M Application Services server.
airvantage.table
Racon objects handling staging database tables, to buffer, consolidate and send structured data.
bit32
This library provides bitwise operations.
checks
Argument type checking API.
coroutine
Coroutine Manipulation.
debug
The Debug Library.
devicetree
This module provides read/write access to system parameters and settings, as well as the ability to receive notifications when they change.
global
Lua global variables.
io
Input and Output Facilities.
lfs
LuaFileSystem.
log
Log library provides logging facilities.
ltn12
The ltn12 namespace implements the ideas described in LTN012, Filters sources and sinks.
math
Mathematical Functions.
mime
The mime namespace offers filters that apply and remove common content transfer encodings, such as Base64 and Quoted-Printable.
modbus
Implementation of modbus RTU, ASCII master.
modbustcp
Implementation of modbus TCP, TCP/RTU and TCP/ASCII.
niltoken
Module to provide Nil token.
os
Operating System Facilities.
pack
A library for packing and unpacking binary data.
package
The package library provides basic facilities for loading and building modules in Lua.
persist
This module allows to save and retrieve Lua values in table-like objects, in a non-volatile way.
returncodes
Common return codes.
sched
Sched is a Lua collaborative scheduler: it allows several Lua tasks to run in parallel, and to communicate together when they need to interact.
serial
The serial library enables communication over the serial port.
sms
This module provides the ability to send and receive SMS (Short Message Service) messages via the embedded radio module.
socket
The socket namespace contains the core functionality of LuaSocket.
socket.ftp
FTP (File Transfer Protocol) is a protocol used to transfer files between hosts.
socket.http
HTTP (Hyper Text Transfer Protocol) is the protocol used to exchange information between web-browsers and servers.
socket.smtp
The smtp namespace provides functionality to send e-mail messages.
socket.url
The url namespace provides functions to parse, protect, and build URLs, as well as functions to compose absolute URLs from base and relative URLs, according to RFC 2396.
ssl
Lua SSL/TLS Socket binding.
ssl.https
HTTPS wrapper to provide high level https capability.
ssl.x509
X509 certificate management API
string
String Manipulation.
system
System related tasks
table
Table Manipulation This library provides generic functions for table manipulation.
timer
Timer module that supports one-time timer, periodic timer and Cron-compatible syntax.
utils.loader
Code loading/unloading utils.
utils.ltn12.source
LTN12 source utils.
utils.path
Path utils.
utils.table
Table utils.
  • ALEOS Application Framework
