WP76xx Firmware Release 6 Components
Oct 24, 2017 - Author: Sierra Wireless - Version 6 - 587 Views
This page describes in details the components included with the Firmware Release, how to build your own custom device image based on Release 6 components and how to download it on your product.
WP76xx Firmware Release 6 combined image
Modem Firmware (Generic)
SWI9X07Y_02.09.02.00 / 002.009_000
002.004
17.08.1
17.08.1 Source
SWI9X07Y_02.09.02.00 Source
(Based on Kernel 3.18 and Yocto 1.7)
    • MCU Firmware: mcuFW.cwe
you may decide to generate a custom Device Image without the full list of components (e.g. without Modem Firmware or without the Linux Distribution). If you do so, when you will flash this image later, only the components included within the custom Device Image package will be updated, the others will remain untouched. By doing this, you shall insure that the untouched components are compliant with the ones you are updating through the custom Device Image.
fwupdate fullinstall <combined_image_file> 192.168.2.2
©2018 Sierra Wireless. All rights reserved.
Get updates on this product
You have been successfully subscribed to this product. To access your subscription click here.
