(Latest Release) WP77xx Firmware Release 14.1
- Aug 23, 2022
- Version: 14.1
This page describes the procedure to update WP77xx with Firmware Release 14.1.
WP77xx firmware is available:
- As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 14.1 Updates, below.
- As separate components for developers that wish to build custom Linux Distribution or Base Legato System images. See WP77xx Firmware Release 14.1 Components
to create custom firmware packages.
| (Windows) 'One-click' tool | 1. If not already done, download the latest USB driver and launch the executable. 2. Download the Firmware 'one-click' (.exe) file for your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R14.1 (Generic — PTCRB) R14.1 (AT&T) R14.1 (Deutsche Telekom) R14.1 (Sierra Wireless) R14.1 (T-Mobile US) R14.1 (Verizon) 3. Connect the target's (e.g mangOH) USB cable to your host. 4. Launch the firmware executable (.exe file) and follow instructions. |
| (Linux) Legato CLI |
1. Download the Firmware .SPK file according to your carrier (Note: If your carrier is not listed and you are unsure which Generic to use, check with your carrier.): R14.1 (Generic — PTCRB) R14.1 (AT&T) R14.1 (Deutsche Telekom) R14.1 (Sierra Wireless) R14.1 (T-Mobile US) R14.1 (Verizon) 2. Connect the target's (e.g mangOH) USB cable to your host 3. Open a terminal and execute the Legato command line for your preferred installation method:
| Leaf Workspace Manager |
Follow the Leaf Workspace Manager instructions to download and install Leaf and set up your CLI development environment. Important: In the 'Search for a target' step, use the following to search for the latest WP77 packages: leaf search -t wp77xx -t stable -t latest |
1. On AirVantage, monitor the system to be updated. 2. Select More > Install Bundle. 3. Select the desired firmware bundle: WP7702 (ATT) Release 14.1 02.36.06.00 WP7702 (Generic) Release 14.1 02.36.06.00 (Note: Generic GCF/PTCRB) WP7702 (Sierra) Release 14.1 02.36.06.00 WP7702 (Verizon) Release 14.1 02.22.12.00 4. Start the install procedure. The operation will now be "In progress" state and visible in the System Operations widget. |
For details about this firmware release, refer to the WP77xx Release 14.1 Customer Release Notes
| Carrier Approval |
| Generic (PTCRB) |
SWI9X06Y_02.36.06.00 / 001.071_001 |
002.015 |
SWI9X06Y_02.36.07.00 |
19.11.5 |
| AT&T |
SWI9X06Y_02.36.06.00 / 001.067_001 |
002.015 |
19.11.5 |
| Deutsche Telekom |
002.015 |
19.11.5 |
| Sierra Wireless |
SWI9X06Y_02.36.06.00 / 001.043_001 |
002.015 |
19.11.5 |
| T-Mobile US |
002.015 |
19.11.5 |
| Verizon |
SWI9X06Y_02.22.12.00 / 001.042_002 |
002.015 |
19.11.5 |
