WP77xx Firmware Release 14.1
  • Aug 23, 2022
  • Version: 14.1
This page describes the procedure to update WP77xx with Firmware Release 14.1.
WP77xx firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 14.1 Updates, below.
  • As separate components for developers that wish to build custom Linux Distribution or Base Legato System images. See WP77xx Firmware Release 14.1 Components  to create custom firmware packages.
         R14.1 (Generic — PTCRB)
         R14.1 (AT&T)
         R14.1 (Deutsche Telekom)
         R14.1 (Sierra Wireless)
         R14.1 (T-Mobile US)
         R14.1 (Verizon)
(Linux) Legato CLI
         R14.1 (AT&T)
         R14.1 (T-Mobile US)
         R14.1 (Verizon)
Leaf Workspace Manager
      WP7702 (ATT) Release 14.1 02.36.06.00
      WP7702 (Generic) Release 14.1 02.36.06.00  (Note: Generic GCF/PTCRB)
      WP7702 (Sierra) Release 14.1 02.36.06.00
      WP7702 (Verizon) Release 14.1 02.22.12.00
For details about this firmware release, refer to the WP77xx Release 14.1 Customer Release Notes .
Generic (PTCRB)
SWI9X06Y_02.36.06.00 / 001.071_001
002.015
SWI9X06Y_02.36.07.00
19.11.5
AT&T
SWI9X06Y_02.36.06.00 / 001.067_001
002.015
19.11.5
Deutsche Telekom
002.015
19.11.5
Sierra Wireless
SWI9X06Y_02.36.06.00 / 001.043_001
002.015
19.11.5
T-Mobile US
002.015
19.11.5
Verizon
SWI9X06Y_02.22.12.00 / 001.042_002
002.015
19.11.5
