(Latest Release) WP77xx Firmware Release 15.1
  • Apr 27, 2023
  • Version: 1
This page describes the procedure to update WP77xx with Firmware Release 15.1.
WP77xx firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 15.1 Updates, below.
  • As separate components for developers that wish to build custom Linux Distribution or Base Legato System images. See WP77xx Firmware Release 15.1 Components to create custom firmware packages.
         R15.1 (Generic — PTCRB)
         R15.1 (AT&T)
         R15.1 (Telstra)
         R15.1 (Sierra Wireless)
         R15.1 (Verizon)
(Linux) Legato CLI
         R15.1 (AT&T)
         R15.1 (Telstra)
         R15.1 (Verizon)
Leaf Workspace Manager
      WP7702 (ATT) Release 14.1 02.36.06.00
      WP7702 (Generic) Release 14.1 02.36.06.00  (Note: Generic GCF/PTCRB)
      WP7702 (Sierra) Release 14.1 02.36.06.00
      WP7702 (Verizon) Release 14.1 02.22.12.00
For details about this firmware release, refer to the WP77xx Release 15.1 Customer Release Notes
Generic (PTCRB)
SWI9X06Y_02.36.08.09 / 001.079_000
002.015 SWI9X06Y_03.00.13.00
21.05.0
AT&T
SWI9X06Y_02.36.06.00 / 001.067_005
002.015
21.05.0
Telstra
SWI9X06Y_02.36.08.02 / 001.061_001
002.015
21.05.0
Sierra Wireless
SWI9X06Y_02.36.08.09 / 001.049_000
002.015
21.05.0
Verizon
SWI9X06Y_02.22.12.00 / 001.042_004
002.015
21.05.0
(Latest Release) WP77xx Firmware Release 15.1 | Source
