WP76xx Firmware Release 16 Components
Aug 24, 2020 - Author: Sierra Wireless - Version 16 - 29974 Views
WP76xx Firmware Release 16 combined image
Modem Firmware (Generic — GCF & PTCRB)
SWI9X07Y_02.37.03.00 / 002.095_000
Modem Firmware (AT&T  — PTCRB)
SWI9X07Y_02.37.00.00 / 002.098_000
Modem Firmware (Sierra Wireless — GCF)
SWI9X07Y_02.37.03.00 / 001.060_000
Modem Firmware (Sprint — GCF)
SWI9X07Y_02.37.02.00 / 001.027_000 Download
Modem Firmware (T-Mobile — PTCRB)
SWI9X07Y_02.35.02.00 / 001.017_000 Download
Modem Firmware (Verizon — GCF)
SWI9X07Y_02.37.06.00 / 002.107_000
002.015
SWI9X07Y_02.37.07.00
Download R16
19.11.2
 Legato Source Release #
19.11.2 Source
 R16 (Based on Kernel 3.18.140 and Yocto 2.5)
SWI9X07Y_02.37.07.00 Source
  2. Select the "Target Menu".
©2024 All rights reserved
