WP76xx Firmware Release 16.3
Jun 08, 2023 - Author: Sierra Wireless - Version 2 - 5164 Views
WP76xx firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 16.3 Updates, below.
    See WP76xx Firmware Release 16.3 Components to create custom firmware packages.
'One-click' tool
         R16.3 (Generic — GCF) — WP7607, WP7607-1, WP7608, WP7608-1, WP7609
         R16.3 (Generic — PTCRB) — WP7611, WP7611-1
         R16.3 (AT&T) — WP7611, WP7611-1
         R16.3 (T-Mobile) — WP7611, WP7611-1
         R16.3 (Verizon) — WP7611, WP7611-1
         R16.3 (DOCOMO) — WP7605
         R16.3 (KDDI) — WP7605
         R16.3 (LGU) — WP7609
         R16.3 (SoftBank) — WP7605
         R16.3 (Telstra) — WP7609
         R16.3 (Sierra Wireless) — WP7607, WP7607-1, WP7608, WP7608-1, WP7611,  WP7611-1
MBPL (Linux)
Leaf Workspace Manager
For details about this firmware release, refer to the WP76xx Release 16.3 Customer Release Notes.
Generic — GCF and PTCRB
SWI9X07Y_02.37.06.05 / 002.121_002 002.015
SWI9X07Y_02.37.10.02 19.11.6
AT&T  SWI9X07Y_02.37.03.05 / 002.126_000 002.015 SWI9X07Y_02.37.10.02 19.11.6
T-Mobile (TMO) SWI9X07Y_02.35.02.00 / 001.017_001 002.015  SWI9X07Y_02.37.10.02  19.11.6
Verizon  SWI9X07Y_02.37.06.05 / 002.123_000 002.015  SWI9X07Y_02.37.10.02  19.11.6
DOCOMO  SWI9X07Y_02.28.03.05 / 001.024_001 002.015  SWI9X07Y_02.37.10.02  19.11.6
KDDI  SWI9X07Y_02.28.03.05 / 001.026_002 002.015  SWI9X07Y_02.37.10.02  19.11.6
LGU  SWI9X07Y_02.32.03.01 / 001.026_001 002.015  SWI9X07Y_02.37.10.02  19.11.6
SoftBank  SWI9X07Y_02.28.03.05 / 001.028_001 002.015  SWI9X07Y_02.37.10.02  19.11.6
Telstra  SWI9X07Y_02.28.03.05 / 001.058_001  002.015  SWI9X07Y_02.37.10.02  19.11.6
Sierra Wireless  SWI9X07Y_02.37.06.05 / 001.072_000   002.015   SWI9X07Y_02.37.10.02   19.11.6
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 16.3 components and how to download it on your product.
©2024 All rights reserved
