(Latest Release) WP77xx Firmware Release 15.1
Apr 27, 2023 - Author: Sierra Wireless - Version 1 - 1994 Views
WP77xx firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 15.1 Updates, below.
  • As separate components for developers that wish to build custom Linux Distribution or Base Legato System images. See WP77xx Firmware Release 15.1 Components to create custom firmware packages.
         R15.1 (Generic — PTCRB)
         R15.1 (AT&T)
         R15.1 (Telstra)
         R15.1 (Sierra Wireless)
         R15.1 (Verizon)
(Linux) Legato CLI
         R15.1 (AT&T)
         R15.1 (Telstra)
         R15.1 (Verizon)
Leaf Workspace Manager
      WP7702 (ATT) Release 14.1 02.36.06.00
      WP7702 (Generic) Release 14.1 02.36.06.00  (Note: Generic GCF/PTCRB)
      WP7702 (Sierra) Release 14.1 02.36.06.00
      WP7702 (Verizon) Release 14.1 02.22.12.00
For details about this firmware release, refer to the WP77xx Release 15.1 Customer Release Notes
Generic (PTCRB)
SWI9X06Y_02.36.08.09 / 001.079_000
002.015 SWI9X06Y_03.00.13.00
21.05.0
AT&T
SWI9X06Y_02.36.06.00 / 001.067_005
002.015
21.05.0
Telstra
SWI9X06Y_02.36.08.02 / 001.061_001
002.015
21.05.0
Sierra Wireless
SWI9X06Y_02.36.08.09 / 001.049_000
002.015
21.05.0
Verizon
SWI9X06Y_02.22.12.00 / 001.042_004
002.015
21.05.0
(Latest Release) WP77xx Firmware Release 15.1 Components
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 15.1 components and how to download it on your product.
©2024 All rights reserved
