WP8548 & WP75xx Firmware Release 16.1/17 Components
Sep 11, 2023 - Author: Sierra Wireless - Version 16.1/17 - 15516 Views
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 16.1/17 components and how to download it on your product.
WP8548 & WP75xx Firmware Release 16.1/17 combined image
Modem Firmware (Generic — GCF/PTCRB)
SWI9X15Y_07.13.07.00 / 001.040_000
Modem Firmware (Generic — Anatel)
SWI9X15Y_07.14.01.00 / 001.042_000
Modem Firmware (AT&T)
SWI9X15Y_07.13.07.00 / 001.036_000
Modem Firmware (Sprint)
SWI9X15Y_07.13.07.00 / 001.027_000
002.004
SWI9X15Y_07.13.05.00
18.06.4
18.06.4 Source
Release 16.1: SWI9X15Y_07.13.05.00 Source
(Based on Kernel 3.14 and Yocto 2.2)
Open Source Licenses Release 16.1:
32-bit ToolChain
 Release 17: SWI9X15Y_07.14.01.00 Source
 Release 17:
32-bit ToolChain
    • MCU Firmware: mcuFW.cwe
©2024 All rights reserved
