This page shows examples from AirLink RX400 and AirLink EX400 routers. Both products have the same Wi-Fi features and functionality.
When configured as a Wi-Fi Access Point, multiple (up to 16) wireless devices can connect to the router and use the router’s WAN connection to access the network. The router can also be configured as a Wi-Fi Client where the router can connect to another Wi-Fi network to access the WAN, replacing the router’s previously active WAN connection.
The router has one Wi-Fi interface, which you can set to operate as:
Access Point (2.4GHz or 5GHz)
Client (2.4GHz, 5GHz, or 2.4GHz + 5GHz)
The REGION field is the regulatory domain that the router Wi-Fi is using. It is determined by using either the Global Navigation Satellite System (GNSS) sensors in the router, or by the Mobile Country Code (MCC) or Mobile Network Code (MNC) received from the carrier and received directly by the receiver on the device. The router automatically loads the operating frequencies and transmit power levels for that regulatory region in the software and enables 802.11d for broadcasting the newly obtained country information. If the router is not able to determine the region, it uses only channels that are available globally. For more information on supported channels, please refer to the Wi-Fi specifications in the AirLink RX400-EX400 Hardware User Guide .
A PLACEMENT switch appears for supported regions outside North America. The switch can limit the available 5GHz Wi-Fi channels according to regional regulatory requirements for indoor and outdoor use. The PLACEMENT options are Indoor (default) and Outdoor.
For more information on supported channels, refer to the Wi-Fi specifications in the AirLink RX400-EX400 Hardware User Guide .
NOTES:
- The region and, if applicable, PLACEMENT option applies to both AP and Client mode. In Client mode, the router will only be able to connect using the applicable channels.
- Available channels may differ, depending on the region’s regulatory requirements.
- Enabling DFS Channels will make DFS-specific channels available in AP mode regardless of the region and, if applicable, PLACEMENT option. DFS (Dynamic Frequency Selection) channels are always enabled when Wi-Fi is in Client mode.
For details on how your router is determining its region, go to Status > Services > Geolocation.
at the end of the row in the WI-FI INTERFACES table (as shown above).
- Enabling DFS allows for more 5GHz channels, but may result in delayed connectivity at boot and in the presence of radar.
- If the router Access Point (AP) switches channels because of radar activity, the AP does not broadcast for about 30 minutes. In addition, Semtech recommends against configuring the AP interface during that time, otherwise the AP will not resume broadcasting until the router is restarted.
Enable LEGACY MODE to restore security option WPA (version 1) and support TKIP encryption for WPA/WPA2 modes. By default, this is disabled and only AES encryption is supported.
For WPA2 and WPA2/WPA3 Transition Mode only, select the 802.11W option.
On Status > System > Dashboard, the LAN dashboard shows you the Wi-Fi LAN interfaces and the LAN segments they use. A blue Access Point icon (
Additionally, you can go to Status > System > Wi-Fi to view detailed Wi-Fi Access Point status, including the active channel and connected stations (clients).
You can create a Client Mode configuration by using a scanned SSID from the Client SSID Database, or by creating an SSID. The router will use the SSID for its WAN connection.
For more information, see this Semtech Customer Community article.
Tips:
Rest the pointer on an SSID to view the channel, BSSID and RSSI for each band.
To use a scanned SSID:
To create an SSID manually:
| SETTING | DESCRIPTION |
| TYPE | Root Certificate |
| NAME | Required name identifying the certificate |
| ROOT CERTIFICATE | Click to upload the root certificate file |
| TYPE | Certificate |
| PRIVATE KEY | Click to upload the private key |
To complete or edit the Client mode configuration, click
In Edit Wi-Fi Interface, configure the fields in any order.
Set the SSID SELECTION switch.
When you have multiple SSIDs configured, Semtech recommends leaving SSID SELECTION at the default Auto (Highest Priority) setting. The router will automatically search and connect to an SSID depending on priority. If priorities are identical, the router will use the closest SSID with the fastest estimated link speed.
To configure the Wi-Fi client to use only a single, specific SSID, set SSID SELECTION to “Manual” and then choose the CONFIGURED SSID to which the router will connect.
DFS CHANNELS is enabled when BAND is set to 5GHz or 2.4GHz + 5GHz. This non-configurable setting opens up more Wi-Fi channels for the router to use, while preventing the router interfering with channels used by radar equipment (near airports, for example). With DFS CHANNELS enabled, the router will switch channels if it detects radar equipment using the same channel.
When BAND is set to 5GHz, select the CHANNEL BANDWIDTH to use. Each 20 MHz of bandwidth corresponds to 1 channel (i.e., 1 channel = 20 MHz, 4 channels = 80 MHz). The options are:
Enter the SCAN INTERVAL, which sets how often the router scans for SSIDs when disconnected. The options are:
Set MSS CLAMPING — MSS (Maximum TCP Segment Size) Clamping controls the maximum packet size used for TCP connections between a local (LAN-side) host and a remote host over the Wi-Fi WAN interface. MSS Clamping helps avoid possible issues with sending and receiving large TCP packets over the cellular network when other standard MTU mechanisms do not appear to be working with your installation. The options are:
MSS — When MSS CLAMPING is set to Manual, set the Maximum TCP Segment Size.
On Status > Dashboard, the WAN and LAN dashboards show you the Wi-Fi interfaces. A grey Wi-Fi icon (
Additionally, you can go to Status > System > Wi-Fi to view detailed Wi-Fi Client or Access Point status.
Some Wi-Fi security modes with specific configuration settings are equivalent to other modes, which may cause overlap between Access Point and Client security modes. In some situations, the router client may report the security mode selected by the Access Point (some WPA2-Enterprise modes can appear as WPA3-Enterprise, for example), which may not be expected considering the router’s configured security mode.
