AirLink routers are equipped with location tracking, enabling you to track the movements of a vehicle or other devices that move. The router relays the information of its location as well as other data for use with tracking applications.
Trimble® ASCII Interface Protocol (TAIP): TAIP is a digital communication interface based on printable ASCII characters over a serial data link.
Ensure that a GNSS antenna is connected to the router. See the RX400-EX400 Hardware Guide for installation and antenna connection instructions. For compatible antennas sold by Semtech, see our website.
After enabling GNSS with the antenna connected, check the GNSS LED to confirm GNSS operation. The GNSS LED will be red while searching for a fix. After getting a fix, it is green.
For legacy applications that may require GPS-only, you can limit the location service by selecting the “GPS Only” option. See LOCATION CONSTELLATION below.
To enable GNSS, go to Services > Location > General and click the switch under GNSS ENABLE.
Router geolocation uses cellular or GNSS fix. If the router has no cellular connection and GNSS is disabled, the geolocation for the Wi-Fi will be “Unknown” and Wi-Fi will be restricted to 2.4 GHz channels only.
GNSS status is reported under GNSS STATE, and can include the following status messages:
| MAXIMUM VEHICLE SPEED (KM/H) | This setting helps to filter out erroneous location fixes by setting an expectation of the vehicle’s maximum achievable speed. | 0—1000 | 250 |
| LOCATION CONSTELLATION | Location constellation you want the router to use |
GNSS (GPS, Galileo, QZSS, GLONASS) |
| NMEA LOGGING | You can enable NMEA LOGGING to have the router log NMEA sentences to temporary files (lost upon reboot). The logging can hold up to the last 24 hours of NMEA sentences. After collecting the raw NMEA data, you can save it by generating and downloading an NMEA log file under System > Logs > NMEA Logs. | Off, On | Off |
Under Location > Reporting:
Local reports are sent via UDP to a LAN segment or to a specific IP address on the LAN.
To configure Local Reporting:
| NAME | Enter a name for the report. | n/a | n/a |
| SERVICE | The protocol over which reporting traffic is sent. UDP Broadcast sends traffic to a subnet, while UDP Unicast sends traffic to a specific device on a LAN segment. When UDP Unicast is selected, you must enter a Destination IPv4 address. | UDP Broadcast or UDP Unicast | UDP Broadcast |
| DESTINATION IPV4 ADDRESS (UNICAST ONLY) |
This setting is available when UDP Unicast service is selected. To send the location report(s) to a local LAN client, enter the address here. If there is more than one local client at the Destination IPv4 Address, you can set up a DHCP reservation or set a static IP address for the client that will receive the report.
n/a | n/a |
| DESTINATION PORTS | Enter the port(s) on which the CAD/AVL application is configured to receive data. The port number(s) should be available from your CAD/AVL administrator or application documentation. | 1–65535 | 65278 |
| DESTINATION LAN SEGMENT |
Enter the LAN segment to which reports will be sent. For UDP Broadcast, reports will be sent to the subnet of the Destination LAN Segment. For UDP Unicast, reports will be sent to the Destination IPv4 Address in the Destination LAN Segment. If you need to send Local Reports to multiple LAN segments, create a separate Local Report for each LAN segment. |
n/a | n/a |
| SOURCE PORT | If you require the ability to control the UDP source port for sending local location reports, enter a port number. In some cases, the SOURCE PORT and DESTINATION PORT may need to match. The setting is blank by default. If blank, the router selects a random source port. | 1–65535 | Blank |
| REPORTING INTERVAL | Sets how frequently the location report is sent to the LAN or IPv4 destination. | 1–100000 seconds | 5 |
| REPORT TYPE |
NMEA |
| SENTENCES |
GGA, GSA, RMC, VTG, GSV, Proprietary Device ID | GGA, GSA, RMC |
| NAME | Enter a name for the reporting server configuration. | n/a | n/a |
| PROTOCOL | Select the protocol over which remote reporting traffic will be sent. | TCP, UDP | UDP |
| DESTINATION HOSTNAME OR IP |
IP address or FQDN (fully qualified domain name) of the server where location reports are sent. Example: 192.100.100.100. The IP address can be for a local host or a remote server that is accessed over-the-air or via a VPN tunnel. If an IP with the last octet of 255 is configured (i.e. 192.168.13.255), a report would be broadcast to all IPs on that subnet. When configured to a local host subnet, any connected device would receive the report. |
n/a | n/a |
| DESTINATION PORT | Destination port on the server where location reports are sent. The destination port can be the same for all servers or you can configure a different destination port for each server. | 1–65535 | 22335 |
| SOURCE ADDRESS | Enter a source address. The IP address has to match that of a configured LAN segment. If passed through a VPN, the router’s “default-LAN” IP address will be used by default. If NOT passed through a VPN, the router’s WAN IP address will be used instead. If left blank, the SOURCE ADDRESS is the IP address of the Default-LAN. | IPv4 or IPv6 address | Blank |
| SOURCE PORT | If you require the ability to control the UDP/TCP source port for sending location reports, enter a port number. In some cases, the SOURCE PORT and DESTINATION PORT may need to match. | 1–65535 | 22335 |
| REPORTING INTERVAL | Sets how frequently the location report is sent to the IPv4 destination. | 1–100000 seconds | 5 |
| REPORT TYPE |
NMEA |
| SENTENCES |
Go to Telemetry > Custom Reports and click CREATE REPORTS.
In Create Reports, enter the following settings:
Click CREATE.
To generate a report on state change of the GPIO input, go to UNCONDITIONAL TRIGGERS and click CREATE UNCONDITIONAL TRIGGERS.
In the Create Unconditional Triggers window, enter the following settings:
Click CREATE.
Under Telemetry > MQTT, configure the connection to your MQTT server. See Configuring Telemetry for more information about MQTT settings.
