To reduce the router’s power consumption, you can turn off the LEDs by going to System > LEDs > LED Powersaver Mode and clicking ENABLE. For more information, see LEDs.
Solid Green
Solid Red
Fast Flashing Red
Slow Flashing Red
Off
Slow Flashing Green
Slow Flashing Purple
Off
| RSSI | RSSI | RSRP | SNR | |
Slow Flashing Green
Slow Flashing Red
Off
Solid Green
Fast Flashing Green
Solid Yellow
Fast Flashing Yellow
Solid Red
Note: If the router is in standby mode, the Power LED will be solid red only if the AirLink OS Standby LED setting is enabled (System > Power Management > Standby Mode), otherwise the LED will be Off. (By default, the setting is enabled.)
Fast Flashing Red
Slow Flashing Red
Off
Yellow LED chase pattern
Green LED chase pattern
