    Configuring Telemetry
    Telemetry data collection requires the router to be properly installed and connected to the vehicle. For most applications, you must connect the router’s ignition line (white wire on the power connector) to the vehicle ignition, and connect the router to the vehicle bus as described in the RX400-EX400 Hardware User Guide.
    General
    Telemetry Status
    To view the status of your telemetry configuration, go to Status > Services > Telemetry.
    Custom Reports
    REPORTS
    Define reports with your specific data requirements that can be sent to an MQTT broker.
    SETTING DESCRIPTION
    REPORT MODE Destination of where reports will be sent to. The MQTT configuration will only display when the REPORT MODE is set to the MQTT option.
    GENERATE THIS REPORT AT POWER ON
    Report that will be generated when the device powers on.
    Note: Only one report can be selected.
    GENERATE THIS REPORT AT POWER OFF
    Report that will be generated when the device powers off.
    Note: Only one report can be selected, and in situations where there is an abrupt power disconnect a report may not be generated.
    SETTING DESCRIPTION
    EVERY… (SECONDS) Number of seconds between each report interval
    SETTING DESCRIPTION
    AT EVERY SAMPLE OF…
    Options are:
    • Cellular Status
    • Ethernet WAN Status
    • GPIO Input Cumulative
    • HPUE Ethernet Present
    • HPUE Ethernet Status
    • Primary WAN
    • Primary WAN IPv4
    • Primary WAN IPv6
    • WAN Status
    • Wi-Fi AP/STA Status
    Example 2: WAN Ready
    Example 3: Ignition Status
    • Time A: Ignition is DOWN.
    • Time B: Ignition is UP.
    • Time C: Ignition is DOWN.
    Example 4: Primary WAN
    • Time A: Wi-Fi Client is UP and is designated as the PRIMARY WAN. Cellular is also UP.
    • Time B: Wi-Fi Client is UP. Cellular is DOWN.
    • Time B: Wi-Fi Client goes down. The PRIMARY WAN designation is re-evaluated to see if Wi-Fi Client is still the PRIMARY WAN, and it is not. Wi-Fi Client – Down. Cellular – New PRIMARY WAN.
    SETTING DESCRIPTION
    Options are:
    • Cellular Status
    • GNSS Heading (degrees)
    • GNSS Trip Odometer (m)
    • Primary GPIO Input
    • WAN Status
    SETTING DESCRIPTION
    Options are:
    • Cellular Status
    • Ethernet 1 WAN Status
    • HPUE Ethernet 1 Present
    • HPUE Ethernet 1 Status
    • Ignition Status
    • WAN Status
    • Wi-Fi AP 2.4GHz Status
    • Wi-Fi AP Status
    • Wi-Fi Client Status
    <RELATIONAL OPERATOR>
    Options are:
    • > (greater than)
    • >= (greater than or equal)
    • == (equal)
    • <= (less than or equal)
    • < (less than)
    • != (not equal)
    SETTING DESCRIPTION
    Options are:
    • Cellular Status
    • Ignition Status
    • WAN Status
    • Wi-Fi AP Status
    Options are:
    • > (greater than)
    • == (equal)
    • < (less than)
    • != (not equal)
    MQTT
    AUTO GENERATE CLIENT ID Enables the router’s serial number to be used as the client ID. Enable AUTO GENERATE CLIENT ID if your MQTT broker configuration rejects connections with an empty client ID. You can enable and add this setting to a template and apply it to your fleet instead of configuring a unique client ID for every router. Enabled, Disabled Disabled
    CLIENT ID/ GENERATED CLIENT ID
    Enter a unique MQTT client ID for the router, if required by the MQTT broker. Leave blank for the MQTT broker to assign a client ID.
    When AUTO GENERATE CLIENT ID is enabled, the router serial number is displayed as the GENERATED CLIENT ID.
    N/A N/A
    • None
    • Username and Password
    None
    TOPIC
    6Q1099009902AC24/test {
      “atp.ser” :
            “t”: 1693258321.3640001,
            “v” : “6Q1099009902AC24”
            “ts” : 1693268920.464
    • 0: At most one-time delivery. Your data can be lost. No re-transmission outside of TCP.
    • 1: At least one-time delivery. Your data will be re-transmitted if needed. The message can be received more than once.
    • 2: Exactly one-time delivery. The message will be delivered exactly once but the communication overhead is high (multiple acknowledgement messages).
    0
    • ATP FORMAT: ATP FORMAT will use an atp prefix on the data sent to the MQTT broker; for example: atp.GLON
    • NON-ATP FORMAT: Uses the least amount of data over the air; for example: GLON
    ATP FORMAT
    • Individual Timestamp: Timestamp of each sample collected.
    • Report Timestamp: Timestamp of when the report is generated. Least amount of data used.
    CONNECTION SECURITY
    Sets how the security of the MQTT connection is handled.
    AirLink OS supports TLS encryption for MQTT traffic.
    • None
    • Use TLS with Trusted Third-Party CA: Select this when the MQTT broker is using a certificate from a trusted third party certificate authority. The router will search for the root certificate in its internal root certificate store.
    • Use TLS with Custom CA: Select this when the MQTT broker is using a certificate from a self-signed certificate authority. You will need to add a root certificate under ROOT CERTIFICATE (see below).
    None
    ROOT CERTIFICATE
    Any existing root certificate
    N/A
