This router model has one I/O pin available for analog input or digital input/output configuration:
You can use Pin 4 in conjunction with Telemetry to configure the router to send a report when the I/O pin state changes; for example when a switch is opened or closed. The digital input can also be used with the standby timer. For more information, refer to the Hardware Guide for the router.
To set the mode for the I/O pin:
Go to System > I/O > Configuration.
Select the Mode. The mode settings available are:
Once the Mode is selected, a corresponding entry will appear in the Analog Inputs table or the Digital Inputs and Digital Outputs tables.
In the Analog Inputs Table you can transform the voltage readings to a more convenient unit of measurement. For example, degrees Celsius or Fahrenheit for temperature, liters for volume, etc.
0 V is equivalent to –20°C
30 V is equivalent to 100°C
a * 0V + b = –20C
a * 30V + b = 100C
where:
a = coefficient
b = offset
a * 30V = 120V
a = 4
4 * 0V + b = –20
b = –20
Go to System > I/O > Analog Inputs.
Enter the values for the coefficient and offset. (In this example, the coefficient is 4 and the offset is –20.)
Digital inputs monitor contact closures on a switch. This allows you to monitor changes such as:
The Digital Inputs Table displays:
Go to System > I/O > Digital Inputs.
In the DIGITAL INPUTS TABLE, select Active High or Active Low.
Enable/disable the Pull Up.
The power connector GPIO (pin 4) digital input can also be used to put the device into a standby mode and to wake the router up. To configure this, see Configuring Power Settings .
When Power Connector pin 4 is configured as Digital Input and Output, you can configure the Digital Outputs settings. You can use Digital Output to drive a relay or for other uses where a switchable low-side current sink is required.
To enable Digital Output:
Go to System > I/O > Digital Outputs.
In the DIGITAL OUTPUTS TABLE, set Digital Outputs to Pin Grounded.
To view the status of the router’s GPIOs, go to Status > System > I/O (or click the link under Configuration).
The I/O STATUS table shows each enabled I/O Pin and its:
The transformation function uses Raw Value in units of volts, not millivolts, to display the Transformed Value.
Data sampling is taken over 20 measurements during a 250 ms interval. The measurements are averaged to generate a sample. If the sample has changed by the amount of the Deadband or a time period of 2.5 minutes has passed, then the Raw Value is updated.
