    Configuring Wi-Fi
    This page shows you how to configure Wi-Fi for your AirLink RX55 router in Access Point mode and Client mode.
    When configured as a Wi-Fi Access Point, multiple wireless devices can connect to the router and use the cellular WAN to access the network. The router can also be configured as a Wi-Fi Client where the router can connect to another Wi-Fi network, instead of the cellular WAN.
    Wi-Fi Interfaces
    • Wi-Fi A
    • Wi-Fi B
    Each interface is configurable as Access Point (2.4GHZ or 5GHz) or Client (2.4GHz, 5GHz, or 2.4GHz + 5GHz).
    The REGION field is the regulatory domain that the router Wi-Fi is using. It is determined by using either the Global Navigation Satellite System(GNSS) sensors in the router, or by the Mobile Country Code (MCC) or Mobile Network Code (MNC) transmitted by the carrier and directly received by the device’s receiver. The router will automatically load the operating frequencies for that regulatory region on each Wi-Fi radio interface in the software and will enable 802.11d for broadcasting the newly obtained country information. If the router is not able to determine the region, it will default to the factory defined setting and disable 802.11d.
    Depending on the Region, an OUTDOOR field may optionally be displayed. This allows you to restrict the available channels according to Wi-Fi region regulations. The default is Disabled, indicating an Indoor configuration, which will follow standard regulatory compliance requirements. Outdoor deployments may have additional regulatory considerations, especially if they operate in certain frequency bands. This option will be removed in AirLink OS Release 5.1.
    To configure an interface as an Access Point, click at the end of a row for Wi-Fi A or Wi-Fi B in the WI-FI INTERFACES table (as shown above).
    • ENABLE the interface.
    • Select the MODE — Access Point in this case.
      Best Practice recommendation: If 2.4GHz and 5GHz APs are configured on different LAN segments, use different SSIDs and security passphrases to make sure DHCP renews IP adresses when switching between the APs.
      • WPA — This option appears only when LEGACY MODE is enabled. Requires only a SECURITY PASSPHRASE. (This mode is not recommended.)
      • WPA2-Enterprise — Requires operation; clients that do not support 802.11w will not connect.
      Note: The 802.11w options do not appear for WPA3 or WPA2/WPA3 Transition Mode. For WPA2/WPA3 Transition Mode, ‘Optional’ is automatically used. For WPA3, ‘Required’ is automatically used.
      • Select the RADIUS AUTHENTICATION SERVER to use.
      • Select the RADIUS ACCOUNTING SERVER to use. Note: RADIUS servers must use IPv4 addresses. FQDNs and IPv6 addresses are not supported.
    • Set LEGACY MODE — When enabled, Legacy Mode restores security option WPA (version 1) in the SECURITY MODE list, and supports TKIP encryption for WPA/WPA2 modes. When disabled, only AES encryption is supported.
    • Enable DFS CHANNELS to open up more Wi-Fi channels for the router to use, while preventing the router interfering with channels used by radar equipment (near airports, for example). With DFS CHANNELS enabled, the router will switch channels if it detects radar equipment using the same channel. Unless you know that your other operating equipment is DFS capable, Sierra Wireless recommends leaving DFS CHANNELS disabled.
      • For passenger Wi-Fi applications, enable client isolation to enhance security.
      • Disable client isolation if you have client applications on the same LAN segment that need to interact with each other.
    • Set the MAX NUMBER OF CLIENTS — Enter the maximum number of clients that can connect simultaneously to this access point interface. As a guideline, set a limit that is slightly higher than the number of clients you expect to connect. The default is 10, with a range of 1 to 10.
      • Disabled (default)
    To configure this feature:
    Configuring Wi-Fi Client Mode
    To use a scanned SSID:
    4. Click UPDATE.
    To create an SSID manually:
    3. Select a SECURITY MODE. For mode WPA2 or WPA2 Enterprise, 802.11w options appear. If required, select an option to enable 802.11w operation. The 802.11w standard uses Security Association Query Requests to ensure that clients are legitimate. Options are:
      • Disabled
      • Note: For WPA2/WPA3 Transition mode access points, Optional is used automatically. For WPA3-only access points, Required is used automatically.
    4. Select the PRIORITY. The smaller the value, the higher the priority. Leaving PRIORITY blank puts this SSID at the lowest priority.
    5. Click CREATE.
    • Leave the MODE as Client.
