RX Series routers are equipped with location tracking, enabling you to track the movements of a vehicle or other devices that move. The router relays the information of its location as well as other data for use with tracking applications.
Driver navigation: The router provides real-time location data via the serial or Ethernet port to a local application, including applications that provide mapping and navigation support.
Computer-Aided Dispatch/Automatic Vehicle Location (CAD/AVL): The router provides real-time location data to the server that tracks the location and other variables of the vehicle or asset.
Trimble® ASCII Interface Protocol (TAIP): TAIP is a digital communication interface based on printable ASCII characters over a serial data link. TAIP was designed specifically for vehicle tracking applications but has become common in a number of other applications, such as data terminals and portable computers, because of its ease of use.
Hardware Requirements
Ensure that a GNSS antenna is connected to the router. See the RX55 Hardware Guide for installation and antenna connection instructions. For compatible antennas sold by Sierra Wireless, see our website.
GNSS is the evolution of GPS. GPS uses only a single constellation of satellites, while GNSS uses signalling from up to 4 constellations to provide a more reliable and accurate location fix.
Enabling Location
Starting
Device Unavailable
Waiting For New Fix
Location Fix Acquired
SETTING
DESCRIPTION
RANGE
DEFAULT
GNSS ANTENNA BIAS
Optimize the router for the type of connected GNSS antenna
On
Configuring Location Reports
Under Location > Reporting:
Enter the TAIP ID (used for TAIP reports; not required for NMEA). This can be any four-character alphanumeric string as per the TAIP standard.
Select the NMEA DEVICE ID (PROPRIETARY SENTENCE) (used for NMEA reports; not required for TAIP). Allows use of the router Serial Number or Custom ID (1 to 50 characters) in local IP NMEA reports to identify a device/vehicle. Including the device ID is especially useful when your devices have dynamic IP addresses.
After selecting Custom ID, you must enter the ID in the CUSTOM ID field.
Local Reporting
Local reports are sent via UDP to an IP address on the LAN. For Local Reporting, configure the following:
Service: UDP Broadcast or UDP Multicast. UDP Multicast needs a Destination IPv4 address.
Destination IPv4 Address (Multicast Only): To send the location report(s) to a local LAN client, enter the address here. If there is more than one local client, it is advisable to set up a DHCP reservation or set a static IP address on the client.
Destination Ports: Enter the port on which the CAD/AVL application is configured to receive data (65278 is the default). The port should be available from your CAD/AVL administrator or application documentation.
Destination LAN Segments: Enter the LAN bridges (network segments) for multiple clients. If you have multiple clients that require the location reports, you can send reports to each client on a particular LAN bridge (network segment).
Reporting Interval: Sets how frequently (in seconds; 5 seconds by default) the location report is sent to the LAN or IPv4 destination.
Report Type: Select the report type (or protocol, as described above).
NMEA
TAIP PV report: TAIP location report that contains PV (Position/Velocity Solution) messages
TAIP CP report: TAIP location report that contains CP (Compact Position Solution) messages
TAIP LN report: TAIP location report that contains a long navigation message
TAIP TM report: TAIP location report that contains the time and date
Sentences: If the report type is NMEA, you can select the desired combination of GGA, GSA, RMC, VTG, and GSV sentences, along with the Proprietary Device ID. Some typical sentences are below.
GGA+VTG: NMEA location report that contains fix information, vector track, and speed over ground
GGA+VTG+RMC: NMEA location report that contains fix information, vector track, speed over ground, and recommended minimum location data
GGA+VTG+RMC+GSA+GSV: NMEA location report that contains fix information, vector track, speed over ground, the recommended minimum location data, overall satellite data, and detailed satellite data
Remote Reporting
For Remote Reporting, configure the following REMOTE REPORTING SERVER settings, as applicable:
Protocol: TCP or UDP
Destination Hostname or IP - IP address or FQDN (fully qualified domain name) of the server where location reports are
sent. Example: 192.100.100.100. The IP address can be for a local host or a remote server that is accessed over-the-air or
via a VPN tunnel. If an IP with the last octet of 255 is configured (i.e. 192.168.13.255), a report would be broadcast to all IPs on that subnet. When configured to a local host subnet, any connected device would receive the report. Note: If you want to use it as a LAN device, it must have a private IP address. If you want to use a public IP address, use a Local IP report.
Destination Port: Destination port on the server where location reports are sent. The destination port can be the same for all servers or you can configure a different destination port for each server. Range: 1–65535 (default for the first server is 22335).
Reporting Interval: - Sets how frequently (in seconds; 5 seconds by default) the location report is sent to the IPv4 destination
NMEA
TAIP PV report: TAIP location report that contains position and velocity
TAIP CP report: TAIP location report that contains the compact position
Sentences: For NMEA reports, you can select the desired combination of GGA, GSA, RMC, VTG, and GSV sentences, along with the Proprietary Device ID. Some typical sentences are below.
Under Location > Reporting > LOCAL REPORTING, configure Local Reporting for UDP Multicast using the destination local IP address, for example 192.168.1.1.
Go to Hardware Interfaces.
PAD MODE: UDP
LISTEN FOR CONNECTIONS (AUTO-ANSWER): On
LISTENING PORT and DESTINATION PORT: Same port configured in Step 1
DESTINATION ADDRESS: Same Destination IP Address used in Step 1. For example 192.168.1.1.
Click SAVE.
Go to Telemetry > Custom Reports.
Under REPORT TITLE, enter a report name.
Under REPORT MODE, select one of the MQTT options: MQTT or ALMS and MQTT.
Under MQTT TOPIC REPORT NAME, enter a report name. In the below image, the report is named avgpi (AirVantage General Purpose Inputs).
Under REPORT CONTENT, select GPIO ARA from the list.
GPIO ARA consists of the following data points:
atp.glon: GPS longitude (decimal degrees)
atp.glat: GPS Latitude (decimal degrees)
atp.ghed: GPS Heading (decimal degrees)
atp.gpi: GPIO Input Cumulative, which is a binary report of all five GPIO data points:
Primary GPIO Input (on power connector) 0th bit: atp.pgpio
GPIO Input 2 bit position 1: atp.gpio2
GPIO Input 3 bit position 2: atp.gpio3
GPIO Input 4 bit position 3: atp.gpio4
GPIO Input 5 bit position 4: atp.gpio5
Primary GPIO Input: true
GPIO Input 2: true
GPIO Input 3: false
GPIO Input 4: true
GPIO Input 5: false
To generate a report on state change of one of the GPIO inputs, go to Unconditional Triggers and turn on ENABLE and select the GPIO report under GENERATE THIS REPORT….
Set the AT EVERY SAMPLE OF… to GPIO Input Cumulative.
Click SAVE.
