reset using factory defaults
reset using a custom template
| HOLD BUTTON FOR ... | ACTION | POWER LED BEHAVIOR |
| < 5 seconds | Release to reboot the router | Fast flashing green |
| 5 to 20 seconds | Release to reset to the RESET CONFIGURATION TYPE state | Fast flashing red |
| 20 to 40 seconds | Release to reset to factory defaults | Fast flashing yellow |
| Over 40 seconds | Release to cancel reset | Fast flashing yellow and red |
RESET CONFIGURATION TYPE: This setting is used to specify what type of reset configuration will be used when resetting the router configuration.
Click RESET SETTINGS to reset the router. A confirmation screen will appear.
Click CANCEL to cancel the reset, or click RESET SETTINGS to reset.
