    Reading Router LED Colors and Patterns
    To reduce the router’s power consumption, you can turn off the LEDs by going to System > LEDs > LED Powersaver Mode and clicking ENABLE. For more information, see LEDs.
    Patterns
    • Solid: Single color, always on
    • Fast flashing: One color on for 0.2 s, then off or another color for 0.2 s
    • Slow Flashing: One color on for 0.25 s, then off or another color for 0.75 s
    • Pulse: One color on for 0.5 s, then a 0.2 s pulse off or another color
    • Chase: All LEDs on for 0.2 seconds in sequence from left to right, continuously
    GNSS
    Solid Green
    • Satellite fix is available
    Solid Red
    • Searching for a satellite fix
    Fast Flashing Red
    • GNSS antenna is open or shorted.
    Slow Flashing Red
    • GNSS antenna is disconnected.
    Off
    • GNSS is off or disabled
    WI-FI
    • Connected in client mode (good signal) with traffic
    Slow Flashing Green
    • Wi-Fi client is enabled but not connected, and no AP is enabled
    • Connected in client mode (fair signal) with traffic
    • Connected in client mode (poor signal) with traffic
    • AP with traffic, and Wi-Fi client enabled but no connection or
    • AP with traffic, and Wi-Fi client disabled
    Off
    • No Wi-Fi enabled (no AP, no Wi-Fi client)
    CELLULAR
    BARS GSM/2G WCDMA/3G LTE/4G and 5G
    RSSI RSSI RSRP SNR
    5 x ≥ -78 x ≥ -76 x ≥ -85 x ≥ 130
    4 -78 > x ≥ -87 -76 > x ≥ -83 -85 > x ≥ -95 130 > x ≥ 50
    3 -87 > x ≥ -93 -83 > x ≥ -93 -95 > x ≥ -105 50 > x ≥ 10
    2 -93 > x ≥ -102 -93 > x ≥ -103 -105 > x ≥ -115 10 > x ≥ -30
    1 -102 > x ≥ -109 -103 > x ≥ -113 -115 > x ≥ -1000 -30 > x ≥ -200
    0 x < -109 x < -113 x < -1000 x < -200
    • Connected to the network with a good connection (equivalent to 4–5 bars)
    Slow Flashing Green
    • Connecting to the network
    • Connected to a network with a fair connection (equivalent to 2–3 bars)
    • Connected to a network with a poor connection (equivalent to 1 bar)
    Slow Flashing Red
    • No network connection
    Off
    • Cellular radio disabled
    POWER
    Solid Green
    • Router operating normally with ignition on
    Fast Flashing Green
    • Router is rebooting after Reset button pressed for <5 seconds (or reset from AirLink OS)
    Solid Yellow
    • Router is booting or
    • the router is thermally throttled — one or more of CPU, cellular radio, and Wi-Fi radio has exceeded threshold. When operating temperature returns to normal, LED returns to solid green.
    Fast Flashing Yellow
    • Router is rebooting and being reset to factory defaults, after Reset button is pressed for 20 to 40 seconds
    Solid Red
    • Power is present, but the router is not running (ignition is off, router is in standby mode, etc.)
    Note: If the router is in standby mode, the Power LED will be solid red only if the AirLink OS Standby LED setting is enabled (System > Power Management > Standby Mode), otherwise the LED will be Off. (By default, the setting is enabled.)
    Fast Flashing Red
    • Router is rebooting and being reset to the default template, after Reset button is pressed for 5 to 20 seconds
    Slow Flashing Red
    • Router is not operating because the operating temperature range is exceeded (thermal shutdown)
    • Reset button held > 40 seconds, canceling the reset action and rebooting normally when released. If pressing the reset button for more than 5 seconds, and you decide that the router should do a regular reboot (not a reset to default template or factory defaults), continue pressing Reset until the LED flashes Yellow and Red.
    Off
    • No power or the router is in standby mode and the AirLink OS Standby LED setting is disabled (System > Power Management > Standby Mode)
    All LEDs
    A yellow LED chase pattern indicates an AirLink OS software update in progress.
