Manual SIM Switching
AirLink routers have two SIM card slots and can support a primary and secondary SIM card. By default, the upper SIM card (SLOT 1) is the primary SIM card used by the first cellular interface (“XP1” on the AirLink XR90, “Cellular” on the AirLink XR80), and the lower SIM card (SLOT 2) is used by the second cellular interface, if installed on the router (“XP2” on the XR90, “XP” on the XR80).
Automatic SIM Switching
For a router with only one cellular interface (that is, a single-radio router), you can configure Automatic SIM Switching (also called SIM failover) to enable the cellular interface to use a different SIM card/SIM slot in response to changes in the cellular network state.
On a single-radio router, switching between SIM cards and different network providers can take 5 to 10 minutes if different radio module firmware is required—the delay includes the time required to reflash the radio module with the appropriate firmware image. During this time, the Cellular WAN interface connection will be interrupted.
To configure Auto SIM Switching, click
in the SIM SLOT MANAGEMENT table and enter the timeout settings that will trigger a SIM switch.
The configurable cases are Roaming Timeout, Service Scan Timeout, Service Lost Timeout and Secondary Slot Timeout. These settings work together, so it’s important to plan how you want automatic SIM switching to work before configuring these fields in order to reduce network downtime on the cellular interface.
| SETTING | DESCRIPTION | RANGE |
| ROAMING TIMEOUT |
If the router has been roaming on a different carrier’s network for longer than the time (in minutes) configured in this field, it automatically switches to the inactive SIM card. This option is useful if the router frequently crosses an international border where there are different Mobile Network Operators in each country. You can set up the router with two SIM cards: one for a Mobile Network Operator in each country. The router then automatically switches to the SIM that is not roaming (after a configured delay) whenever the router crosses the border. |
1–65535 min |
| SERVICE SCAN TIMEOUT |
If the router’s cellular interface has been trying to connect to a network for more than the configured time (in minutes), the router switches to the inactive SIM card. The router will switch SIM cards if the cellular interface has no service after:
The automatic SIM switch is initiated if the router is unable to establish a data connection or if the SIM card is unable to register on the network. If this is a new SIM card, check that the APN in Use is correct and that it is able to register on the network. |
1–65535 min |
| SERVICE LOST TIMEOUT |
If the network’s data connection is lost for more than the configured time (in minutes), the router switches to the inactive SIM card. |
1–65535 min |
| SECONDARY SLOT TIMEOUT |
If the router has been using the secondary SIM card for the time configured in this field (in minutes), the router automatically switches back to the primary SIM card. This allows you to configure the router to fall back to the primary network if, for example, the data rate is better on the primary network. Note that the router will switch SIM cards again if the Service Lost Timeout threshold is met again. Example: After switching back to the primary SIM card (with the Service Lost Timeout set to 30), if there is a service loss for 30 minutes, the SIM will switch to the secondary SIM card and the SECONDARY SLOT TIMEOUT begins again. |
1–65535 min |
