Simple Captive Portal enables you to redirect traffic from Wi-Fi clients to a landing page hosted on the router before granting those clients Web access. Unlike Extended Captive Portal, clients using Simple Captive Portal do not require login credentials or a password to access the Web.
As well, Simple Captive Portal does not require a third-party service like HotSpotSystem. You can also customize the login/splash page and manage the client session length locally without a UAM/RADIUS server. To get you started, Semtech has provided a sample that demonstrates displaying a web page via Simple Captive Portal, which you can download here.
Clients will log in using one of the following options:
Once this pre-configuration is done, you can configure the Simple Captive Portal settings at Networking > Simple Captive Portal.
To configure Simple Captive Portal, go to Networking > Simple Captive Portal and enable it. The Simple Captive Portal settings are listed and described below.
| SETTING | DESCRIPTION |
| ENABLE |
Enable or disable the simple captive portal.
| STATE |
Status of the simple captive portal. The status depends on the mode you’ve selected (see MODE below for more information).
| MODE |
You can select the following modes for displaying the Simple Captive Portal splash page:
| LAN SEGMENT |
Enter the LAN Segment you configured earlier. Clients on this LAN Segment will connect to the Wi-Fi Access Point and be directed to the Simple Captive Portal splash page. |
| SESSION TIMEOUT |
Enter the maximum time (in seconds) a session can stay open before automatically ending.
| UPLOAD SPLASH PAGE |
This button appears in Local mode. Click to upload your splash page file in tar.gz format. For more information, see Configuring a Custom Splash Page
| SPLASH PAGE SERVER | Appears in Remote mode. Enter the IP address or FQDN of the server hosting your splash page files. |
| SPLASH PAGE FILENAME | Appears in Remote mode. Enter the filename of the tar.gz file containing your splash page files. |
| SERVER INTERVAL | Appears in Remote mode. Enter the interval at which the router downloads the splash page from the remote server (the range is 30 to 10,000,000 minutes). |
| USER | Appears in Remote mode. Enter the user name to access the remote server, if required. |
| PASSWORD | Appears in Remote mode. Enter the password to access the remote server, if required. |
As noted above, in Local or Remote mode, you can upload or host your splash page file in tar.gz format (a tool such as 7-Zip can help you create .tar and .tar.gz files). This splash page can be customized with your own graphics, text, and so on.
The .tar.gz file must contain a root folder named webportal that contains the rest of your files (.png or .jpg image files, .css and others). The webportal folder must also contain a login.htm file that allows clients to send a POST to <server>/accept.
If the uploaded file cannot be used (as indicated by the Invalid package status), the last valid splash page set will be used. For example, when changing Mode from Demo to Local or Remote and the upload is not successful or the files are incorrect, the portal will still use the Demo page. If a custom set is in use and changing to a new set fails, the previous custom set will be used until a new set successfully uploads.
In the AUTHENTICATED CLIENTS table, you can view information about devices (LAN IP Address, device MAC address and Session Expiry time) that have connected to the WAN using the Simple Captive Portal.
