| VEHICLE IGNITION STATUS | Current vehicle ignition status. Read only. | On/Off/Not Available | Not Available |
| REPORT MODE |
| GENERATE THIS REPORT AT POWER ON | Report that will be generated when the device powers on. Note: Only one report can be selected. |
| GENERATE THIS REPORT AT POWER OFF | Report that will be generated when the device powers off. Note: Only one report can be selected and in situations where there is an abrupt power disconnect a report may not be generated. |
| EVERY …(SECONDS) | Number of seconds between each report interval |
| AT EVERY SAMPLE OF… |
Example 2: WAN Ready
Example 3: Ignition Status
Example 4: Primary WAN
Options are:
Options are:
| <RELATIONAL OPERATOR> |
Options are
Options are:
Options are
The MQTT section will only display if a custom report has the REPORT MODE set to an MQTT option.
| CLIENT ID | Unique vehicle id | N/A | |
None |
| TOPIC |
6Q1099009902AC24/test {
“atp.ser” :
“t”: 1693258321.3640001,
“v” : “6Q1099009902AC24”
“ts” : 1693268920.464
0: At most one-time delivery. Your data can be lost. No retransmission outside of TCP. |
0 |
ATP FORMAT |
Individual Timestamp |
