    Configuring Wi-Fi
    Wi-Fi Interfaces
    • Wi-Fi AP (2.4GHZ or 5GHz)
    • Wi-Fi Client (2.4GHz + 5GHz)
    For example:
    • The router will provide a Wi-Fi Access Point (using the cellular WAN) in the vehicle for laptops and other client devices.
    • The router will also provide a Client mode interface for when the vehicle enters a depot, where the router can connect to another Wi-Fi network (instead of the cellular WAN). The in-vehicle devices can then take advantage of the Wi-Fi WAN network (for example, to upload video camera or vehicle data to the depot network.)
    REGION
    The REGION field is the regulatory domain that the router Wi-Fi is using. It is determined by using either the Global Navigation Satellite System (GNSS) sensors in the router, or by the Mobile Country Code (MCC) or Mobile Network Code (MNC) received from the carrier and received directly by the receiver on the device. The router automatically loads the operating frequencies for that regulatory region on each Wi-Fi radio interface in the software and enables 802.11d for broadcasting the newly obtained country information. If the router is not able to determine the region, it uses a default region setting. For more information on supported channels, please refer to the Wi-Fi specifications in the AirLink XR60 Hardware User Guide .
    PLACEMENT
    • When Indoor is selected, the router can use only the channels allowed for indoor use.
    For more information on supported channels, refer to the Wi-Fi specifications in the AirLink XR60 Hardware User Guide .
    NOTES:
    • Enabling DFS Channels will make DFS-specific channels available to both AP and Client mode regardless of the region and, if applicable, PLACEMENT option.
    For details on how your router is determining its region, go to Status/Monitoring > Services > Geolocation.
    To configure an interface as an Access Point, click at the end of the Wi-Fi AP row in the WI-FI INTERFACES table (as shown above).
    • ENABLE the interface.
      • WPA2 — Requires a SECURITY PASSPHRASE and 802.11w options.
      • WPA2-Enterprise — es RADIUS Authentication & Acceptance server details.
      • Select the RADIUS AUTHENTICATION SERVER to use. This is the primary RADIUS server and is required. If there are no servers in the list, select CREATE and enter the following:
        • LABEL — name of the server
        • TIMEOUT — the time limit for the server to respond. If the server does not respond during the timeout, the authentication fails and the other RADIUS AUTHENTICATION SERVER (if configured) checks the credentials.
        • SECRET — the shared secret used for encryption when a client connected to the device’s AP is connecting to the RADIUS authentication server
      • Optionally select the RADIUS AUTHENTICATION SERVER 2 to specify the backup RADIUS server. Select from the list, or select CREATE.
    • For the RX55 and XR60, both RADIUS authentication servers must have the same shared secret.
      • Disabled
      • For passenger Wi-Fi applications, enable Client Isolation to enhance security.
      • Disable Client Isolation if you have client applications on the same LAN segment that need to interact with each other.
      • Disabled (default)
    Additional Access Point Settings
    Below the WI-FI INTERFACES table, you can configure the settings shown here.
    • USE ADDITIONAL SSIDS — See Adding Additional SSIDs (Virtual Access Points) below.
    • Enable DFS CHANNELS to open up more Wi-Fi channels for the router to use, while preventing the router interfering with channels used by radar equipment (near airports, for example). With DFS CHANNELS enabled, the router will switch channels if it detects radar equipment using the same channel. Unless you know that your operating equipment is DFS capable, Semtech recommends leaving DFS CHANNELS disabled.
      • If the router Access Point (AP) switches channels because of radar activity, the AP does not broadcast for about 30 minutes. In addition, Semtech recommends against configuring the AP interface during that time, otherwise the AP will not resume broadcasting until the router is restarted.
      • The DFS CHANNELS setting is unavailable when Client is enabled and the Access Point BAND is configured for 5GHz.
      • Enabling DFS may result in delayed connectivity at boot.
    • Set the MAX NUMBER OF CLIENTS — Enter the maximum number of clients that can connect simultaneously to all access point interfaces. As a guideline, set a limit that is slightly higher than the number of clients you expect to connect. The default is 32, with a range of 1 to 32.
    • DISABLE APS ON CLIENT ASSOCIATION — See Managing APs During Client Association below.
    A DISABLE APS ON CLIENT ASSOCIATION switch is below the WI-FI INTERFACES table.
    To configure this feature:
    2. Set the DISABLE AP DELAY to the length of time to wait before disabling the router’s Access Point. If no delay is required, set the delay to 0.
    A USE ADDITIONAL SSIDS switch is below the Wi-Fi configuration table. Enable this switch when you require multiple SSIDs broadcasting on separate LAN segments that are configured for different security protocols.
    When enabled, an ADDITIONAL SSIDS table opens, from which you can select, enable, and edit SSIDs (Virtual Access Points — “VAP”s).
    Up to two additional SSIDs can be enabled for the Wi-Fi AP 2.4GHz and Wi-Fi AP 5GHz interfaces (i.e., one for Wi-Fi AP 5GHz and one for Wi-Fi AP 2.4GHz).
    To configure an additional SSID, click at the end of the row in the ADDITIONAL SSIDS table (as shown above).
    This menu is identical to the Edit Wi-Fi Interface menu described above except that the CHANNEL settings cannot be configured. Those settings are inherited from the main Wi-Fi AP interface.
    Configuring the Wi-Fi Radios
    When USE ADDITIONAL SSIDS is enabled, you can configure each radio in the WI-FI RADIO CONFIGURATION table that appears below. These settings override the settings for the AP and Client in the WI-FI INTERFACES table. Note that these are general radio settings that are shared by the AP and Client interfaces.
    • Enable or disable Auto-Channel. When Auto-Channel is disabled, you can select the channel on which to operate.
      • To select the channel, click at the end of a row in the WI-FI RADIO CONFIGURATION table and use the Edit Wi-Fi Interface menu.
    • Select the Channel Bandwidth to use (up to 80 MHz). Each 20 MHz of bandwidth corresponds to 1 channel (i.e., 1 channel = 20 MHz, 4 channels = 80 MHz).
    Configuring Wi-Fi Client Mode
    For more information, see this Semtech Customer Community article.
    Tips:
    • Click SCAN NOW to refresh the SCANNED SSIDS table.
    • Rest the pointer on an SSID to view the channel, BSSID and RSSI for each band.
    To use a scanned SSID:
    4. Click UPDATE.
    To create an SSID manually:
    4. For all security modes except OPEN and WPA2-Enterprise, enter a SECURITY PASSPHRASE of at least 8 characters.
          • USER PASSWORD
            SETTING DESCRIPTION
            TYPE Root Certificate
            SETTING DESCRIPTION
            TYPE Certificate
    5. Select CREATE.
      When you have multiple SSIDs configured, Semtech recommends leaving SSID SELECTION at the default Auto (Highest Priority) setting. The router will automatically search and connect to an SSID depending on priority. If priorities are identical, the router will use the closest SSID with the fastest estimated link speed.
    To configure the Wi-Fi client to use only a single, specific SSID, set SSID Selection to “Manual” and then choose the CONFIGURED SSID you wish to connect to.
    Below the WI-FI INTERFACES table, you can configure the following settings:
