    Enabling Reporting in AirLink OS
    The AirLink XR60 router supports the following AMR reports:
    • Trips
    • Zone Summary
    • Trip Replay
    • Coverage Map
    • Coverage Trails
    • Link Utilization
    For optimum reporting performance, connect the router’s ignition line (white wire on the power connector) to the vehicle ignition, and connect the router to the vehicle bus as described in the XR60 Hardware User Guide. Many reports will not function correctly if the router is not wired correctly.
    1. Under Services > Location > General, ensure that GNSS is enabled.
    2. Under Services > Telemetry > General, enable SERVICE.
    3. Under Services > Telemetry > Vehicle set VEHICLE IGNITION WIRING to Connected to AirLink gateway Ignition Sense input line.
    4. Under Services > Telemetry > AMR Reports, enable AMR Reports.
    5. Under MCU > Power Management, configure the ignition SHUTDOWN DELAY to be at least 30 seconds.
      • In the POWER SOURCES table, click Edit ( ) on the row for Source > Ignition.
      • Set the SHUTDOWN DELAY to at least 30 seconds.
      • Click UPDATE.
