    The AirLink XR60 has two SIM card slots that support the cellular interface. By default, the SIM card in the upper slot (slot 1) is the active SIM card.
    Table of Contents
    Cellular Configuration
    • Not all the settings shown below appear when the router is operating without a SIM card installed.
    • Click Show more > to display all the settings shown below.
    • ENABLE
      • Check Manual Radio Firmware: Validating that the required radio module firmware (if Radio Firmware Switching is set to “Manual”) is present and active
      • MultiApn: Checking whether the SIM configuration requires the Cellular interface to operate in multi APN mode
    • BAND 8: By default, LTE band 8 (including 5G n8) is available for the router to use to connect to the cellular network. Disable this setting to prevent band 8 from being used to connect to the network.
    If the router does not automatically connect to the network, contact your Mobile Network Operator to confirm the APN and activation status of your router. You may need to set APN MODE to Manual and enter your carrier’s APN and other credentials.
    • RADIO FIRMWARE SWITCHING: By default, the router automatically selects the radio module firmware. To force the router to use a specific radio module firmware for a different carrier, change RADIO FIRMWARE SWITCHING to Manual, and then select a radio firmware from the list.
      • Automatic (default): When the router powers on or reboots, it automatically selects and uses the appropriate radio module firmware for the active SIM card.
      • Manual: The router does not automatically select the appropriate radio module firmware when it is powered on or rebooted. You must select the radio firmware.
    • SIM CONFIGURATION NAME: By default, the installed SIM(s) and associated configuration(s) are included in the SIM Database. You can enter a name for the current SIM Configuration in this field. The name appears in the SIM Database.
    • PREFERRED TECHNOLOGY: Restrict the router to using a specific cellular technology: Auto (default), 3G Only, 4G Only, 5G Only
    • MIMO CONFIGURATION: Selects the MIMO (Multiple Input/Multiple Output) antenna configuration for the router’s radio module. The cellular antenna bank can have up to 4 antennas connected. Options are:
      • 1×4 (4 antennas)
      • 1×2 (2 antennas) Two-antenna operation requires EM9291 radio module firmware version 03.04.07.00 or later for a carrier that supports this functionality. The antennas should be connected to terminals Cellular 1 and Cellular 3 on the router.
      Important: Two-antenna operation should not be used in applications requiring high throughput. Please consider that omitting two antennas will limit throughput by restricting available data streams. Overall cellular performance may be affected due to increased interference caused by allocating RF streams to only two antenna outputs.
      AirLink XR60 “R2” models support two-antenna operation. You can identify these models by “R2” and IMEI starting with 35182971 printed on the bottom label.
    SIM Slot Management
    The AirLink router has two SIM card slots and is capable of supporting a primary and secondary SIM card. By default, the SIM card in the upper slot (slot 1) is the primary SIM card.
    For more information on SIM Slot Management, see SIM Slot Management and Configuring SIM Failover.
    Multi-APN Configuration
