The installed radio module firmware shown below may vary with your router model and region.
When the update is complete, you can confirm the RMFW configuration under Status > System > Cellular. Check that the FIRMWARE NAME, FIRMWARE VERSION, and FIRMWARE CONFIGURATION have been updated.
Example: If Bell issues a new SIM that has a different Public Land Mobile Network (PLMN) or Integrated Circuit Card Identifier (ICCID) than what is defined in the internal database, then a definition using COS to associate the new PLMN or ICCID to an existing carrier firmware is created.
In the above example,
When RADIO FIRMWARE SWITCHING setting is set to Manual, you can manually switch the radio module firmware to a specific network operator using this process. You can check the RADIO FIRMWARE SWITCHING setting in the Hardware Interfaces > Cellular Interfaces > Configuration section.
As a prerequisite, the RMFW image must be loaded on the router. See Manually Loading the RMFW Image.
Power the router on.
Go to Hardware Interfaces > Cellular Interfaces > Configuration.
Under RADIO FIRMWARE SWITCHING, click Automatic to switch it to Manual.
Under SELECT RADIO FIRMWARE, select your desired carrier.
Click SAVE.
The Cellular ADAPTER STATUS indicates Initializing and then Updating Firmware within a few seconds, as indicated by the green LED chase pattern. The update should take 2–5 minutes depending on the RMFW version it is updating to.
| CARRIER | RMFW VERSION |
| AT&T/FirstNet | 02.15.01.00 |
| Bell | 02.17.08.00 |
| Generic | 03.04.10.01 |
| Rogers | 02.17.08.00 |
| Telstra | 02.17.08.00 |
| Telus | 02.17.08.00 |
| T-Mobile | 02.15.01.00 |
| Verizon | 02.17.08.00 |
