    XR Series routers are equipped with location tracking, enabling you to track the movements of a vehicle or other devices that move. This section describes how the router relays location information as well as other data for use with tracking applications.
    • Computer-Aided Dispatch/Automatic Vehicle Location (CAD/AVL): The router provides real-time location data to a server that tracks the location and other variables of the vehicle or asset.
    Hardware Requirements
    Ensure that a GNSS antenna is connected to the dark blue FAKRA connector on the router. See the XR Series Hardware Guide for installation and antenna connection instructions. For compatible antennas sold by Sierra Wireless, see our website.
    Our GNSS solution can use signalling from up to four constellations to provide a more reliable and accurate location fix. For legacy applications that may require GPS-only, you can limit the location service by selecting the “GPS Only” option. See LOCATION CONSTELLATION below.
    Enabling Location
    • Starting
    • Device Unavailable
    • Waiting For New Fix
    • Location Fix Acquired
    • Firmware Upgrade in Progress
    • Firmware Upgrade Failed
    • Firmware Upgrade Successful
    Status messages related to Firmware are shown after you enable or disable DEAD RECKONING, which changes the GNSS Firmware that the router uses. See DEAD RECKONING below.
    GNSS CURRENT FIRMWARE Current version of firmware on the router’s GNSS (Global Navigation Satellite System) module n/a n/a
    DEAD RECKONING
    Enables or disables Dead Reckoning. After you change the Dead Reckoning setting, the router switches to a different GNSS firmware that supports or does not support Dead Reckoning. Check the GNSS STATE to monitor the progress of the firmware switch.
    Dead Reckoning operates alongside satellite (GNSS) navigation to help maintain location tracking capability when a GNSS signal is impaired or temporarily unavailable. For more information see About Dead Reckoning below.
    On, Off On
    MAXIMUM VEHICLE SPEED (KM/H) This setting helps to filter out erroneous location fixes by setting an expectation of the vehicle’s maximum achievable speed. 0—1000 250 KM/H
    LOCATION CONSTELLATION Location constellation (satellite group) you want the router to use
    • GPS Only
    IGNITION PARK MODE
    You can configure how GNSS location fixes are reported when Ignition is off. The setting can remedy Location Fixes drifting when vehicles are parked and are in Dead Reckoning mode.
    • Non-DR Location Fixes (default)—While parked in marginal coverage, pure Dead Reckoning fixes are ignored (instead of alternating between reporting satellite fixes and pure DR fixes; the router instead alternates between reporting fix and NO FIX).
    • DR and Non-DR Location Fixes—While parked in marginal coverage, pure DR fixes from the GNSS module may continuously drift away without bound.
    • No Location Fix
    On (required for active GNSS antenna) Off (compatible only for passive GNSS antenna)
    On
    GNSS ANTENNA DETECTION Enable/Disable the reporting of GNSS Antenna State under Status/Monitoring > Status > Location. When disabled, GNSS Antenna State is reported as Not available. Off, On Off
    Configuring Location Reports
    Under Location > Reporting:
    Local Reporting
    Local reports are sent via UDP to an IP address on the LAN. To configure Local Reporting, click CREATE below the LOCAL REPORTING table. In the Create Local Reporting window, configure the following settings:
    DESTINATION LAN SEGMENT
    n/a n/a
    REPORT TYPE
    • NMEA
    • NMEA
    • TAIP PV report
    • TAIP CP report
    • TAIP LN report
    • TAIP TM report
    NMEA
    SENTENCES
    Remote Reporting
    To configure the Remote Reporting Server, click CREATE below the REMOTE REPORTING SERVER table. In the Create Remote Reporting Server window, configure the following settings:
    DESTINATION HOSTNAME OR IP
    n/a n/a
    REPORT TYPE
    • NMEA
    • NMEA
    • TAIP PV report
    • TAIP CP report
    • TAIP LN report
    • TAIP TM report
    NMEA
    SENTENCES
    2. Go to Hardware Interfaces.
      • PAD MODE: UDP
      • DESTINATION ADDRESS: Same Destination IP Address used in Step 1. For example, 192.168.1.1.
    5. Click SAVE.
      • NAME: enter a report name.
      • REPORT TITLE: enter a report TITLE.
      • REPORT CONTENT: select GPIO ARA from the list. GPIO ARA consists of the following data points:
      • atp.gpi: GPIO Input Cumulative, which is a binary report of all five GPIO data points:
        • Primary GPIO Input (on power connector) 0th bit: atp.pgpio
        • GPIO Input 2 bit position 1: atp.gpio2
        • GPIO Input 3 bit position 2: atp.gpio3
        • GPIO Input 4 bit position 3: atp.gpio4
        • GPIO Input 5 bit position 4: atp.gpio5
          • Primary GPIO Input: true
          • GPIO Input 2: true
          • GPIO Input 3: false
          • GPIO Input 4: true
          • GPIO Input 5: false
    4. Click CREATE.
    5. To generate a report on state change of the GPIO input, go to UNCONDITIONAL TRIGGERS and click CREATE UNCONDITIONAL TRIGGERS.
      • NAME: Enter a trigger name
      • ENABLE: Enable the trigger
    7. Click CREATE.
    8. Under Telemetry > MQTT, configure the connection to your MQTT server.
    Dead Reckoning is a feature that operates alongside satellite (GNSS) navigation to help maintain location tracking capability when a GNSS signal is impaired or temporarily unavailable. When the feature is enabled, Dead Reckoning uses the router’s built-in inertial sensors to calculate vehicle position and to continue providing location reports to ALMS and other external applications. The router uses its last known GNSS position along with sensor input to calculate vehicle position. For example, when the vehicle enters a tunnel, parking garage, or urban canyon, Dead Reckoning data augments data from the impaired GNSS signal and helps maintain accurate location reporting.
    Enabling Dead Reckoning
    Under Services > Location > General, confirm that DEAD RECKONING is enabled. This setting ensures that Dead Reckoning GNSS firmware is running on the router, and that the router is sending dead reckoning data, as reported by the router’s inertial sensors.
    If DEAD RECKONING is set to Off:
    1. Go to Location > General > DEAD RECKONING and click the “Off” switch, changing it to “On”.
    2. Click SAVE.
      The router switches to using a different GNSS firmware, as reported under GNSS STATE “Firmware Upgrade in Progress”. The status will change to “Waiting For New Fix” and then “Location Fix Acquired”.
    Dead Reckoning can operate in one of two modes, depending on how the router is configured and connected to the vehicle.
    1. Tethered to the vehicle (recommended)—In this mode, the router’s Aux I/O port is connected to OBD-II/J1939 for vehicle speed input, and Vehicle Telemetry Data Collection is enabled. This mode provides a longer, more accurate location fix than Dead Reckoning without an OBD-II/J1939 connection.
    2. Untethered—In this mode, the router is not connected to OBD-II/J1939. Dead reckoning relies only on the router’s inertial sensors to determine vehicle location.
    Sensor Calibration
    When first installed in a vehicle, the router’s GNSS module needs to learn the orientation of the inertial sensors. During this calibration phase, calibration is done most efficiently when the vehicle travels with regular changes in velocity and heading while under good satellite coverage that gives high-confidence location fixes. Driving in an open, flat area with a clear view of the sky is ideal. Driving in traffic may extend the duration of the calibration process. The GNSS module keeps tuning its initial guess of inertial sensor orientation until the movement it calculates from the sensor readings is a good match against the movement derived from satellite fixes. This is why it is desirable to have speed changes and heading changes during the calibration phase, along with good satellite visibility to get high-confidence location fixes as reference during calibration.
    Under these conditions, you can expect the sensors to calibrate in about 15 minutes.
    In summary, for optimal calibration, the vehicle should:
    • be driven in open-sky conditions
    • undergo several turns at “normal” speed (over 30 kmh/20 mph)—left, right, U-turns, circles. Gradual turns, such as lane changes or driving along curves in the road, do not help with calibration.
    • stop and start several times in a straight line, in the same manner that you would brake and accelerate away from stop signs, for example.
    Pure Dead Reckoning Operation
    When out of satellite coverage (such as while driving into an underground parking lot) the GNSS module is no longer able to fine tune for changes in inertial sensor signal levels because there are no longer reference satellite location fixes to adjust against. As a result, the accuracy of the calculations based on sensor data will degrade over time.
    When out of satellite coverage, each location fix is generated by adding the estimated heading and distance of travel calculated from the inertial sensor data to the previous location fix. The estimation errors are carried forward and accumulate with each iteration, and so the synthesized location fixes get more inaccurate over time.
    From testing, Semtech has concluded that after several minutes of pure Dead Reckoning operation (with no GNSS signal), the location fixes being generated are no longer trustworthy, and returning to combined GNSS and Dead Reckoning operation will restore location data accuracy as soon as a satellite fix is acquired.
