    Configuring Wi-Fi
    This page shows you how to configure Wi-Fi for your AirLink XR80 router in Access Point mode and Client mode.
    When configured as a Wi-Fi Access Point (AP), multiple wireless devices can connect to the router and use the router’s WAN connection to access the network. The router can also be configured as a Wi-Fi Client where the router can connect to another Wi-Fi network to access the WAN, replacing the router’s previously active WAN connection.
    Wi-Fi Interfaces
    • Wi-Fi AP 5GHz
    • Wi-Fi AP 2.4 GHz
    • Wi-Fi Client 5GHz
    • Wi-Fi Client 2.4GHz
      The 5GHz AP and Client share one radio, and the 2.4GHz AP and Client share another radio. The interface types cannot be changed — Clients cannot be used as Access Points, and Access Points cannot be used as Clients.
    The REGION field is the regulatory domain that the router Wi-Fi is using. It is determined by using either the Global Navigation Satellite System (GNSS) sensors in the router, or by the Mobile Country Code (MCC) or Mobile Network Code (MNC) received from the carrier and received directly by the receiver on the device. The router will automatically load the operating frequencies for that regulatory region on each Wi-Fi radio interface in the software and will enable 802.11d for broadcasting the newly obtained country information. If the router is not able to determine the region, it will use a default region setting. For more information on supported channels, please refer to the Wi-Fi specifications in the AirLink XR80/XR90 Hardware User Guide .
    Configuring the Wi-Fi Radios
    • In the Physical field, select the network standard to use.
      • 2.4GHz Access Point configuration: In general, select b/g/n/ax, which also uses the latest standard (11ax), and supports legacy compatibility for 11b, 11g, and 11n. b and b/g/n are the other options available.
      • 5GHz Access Point configuration: In general, select n/ac/ax, which uses the latest standard (11ax), and supports legacy compatibility for 11n and 11ac. Typically, only select n/ac for testing any legacy compatibility issues.
    • In the Channel Bandwidth field, select the bandwidth to use (up to 80 MHz). Each 20 MHz of bandwidth corresponds to 1 channel (i.e., 1 channel = 20 MHz, 4 channels = 80 MHz).
    • Select the MIMO (Multiple Input/Multiple Output) configuration for your installation to optimize throughput and signal quality.
      The Wi-Fi antenna bank can have up to 5 Wi-Fi antennas connected. Antenna connectors 1–4 are used for MIMO, and connector 5 is used for scanning 5GHz in Client mode. To enable 5GHz operation, the XR80 must have antennas connected to connectors 1 and 5 (at minimum). See the XR Series Hardware Guide for more information about antennas.
      For antenna connectors 1–4:
      • 4x4 enables all four antennas for sending and receiving traffic
      • 2x4 configures two antennas for sending and four for receiving
      • 1x4 configures one antenna for sending and four for receiving. Select a non-default setting for an access point if you discovered problems with legacy equipment, have fewer than the maximum number of antennas connected, or to improve the XR80’s thermal performance.
    • Enable DFS Channels to open up more 5GHz Wi-Fi channels for the router to use, while preventing the router interfering with channels used by radar equipment (near airports, for example). With DFS Channels enabled, the router’s 5GHz Access Point interface will switch channels if it detects radar equipment using the same channel.
      • Enabling DFS allows for more 5GHz channels, but may result in delayed connectivity at boot and in the presence of radar.
      • Ensure that DFS Channels are enabled whenever the 5GHz Access Point is used. Enabling DFS Channels enhances Client interface connectivity and ensures proper Access Point interface channel operation when in the presence of radar.
    • The Transmit Power Level setting allows you to restrict transmit power to the Wi-Fi antenna(s). The actual transmit power attained depends on a number of factors including the regulatory domain and the wireless channel used. Generally, a higher transmit power setting results in greater Wi-Fi range for the clients. Set for 100% by default, and adjust for network conditions. If clients are connecting with many other clients nearby, high transmit power can cause interference and impede throughput across connected clients.
    To configure an interface as an Access Point, click at the end of an Access Point interface row in the WI-FI INTERFACES table (as shown above).
    • ENABLE the interface. (Note that the Mode cannot be changed.)
      Best Practice recommendation: If the 2.4GHz and 5GHz APs are configured on different LAN segments, use different SSIDs and security passphrases to make sure DHCP renews IP adresses when switching between the APs.
      • WPA — Requires only a SECURITY PASSPHRASE. (This mode is not recommended and will only be seen if the LEGACY MODE is enabled.)
      • Select the RADIUS AUTHENTICATION SERVER to use. This is the primary RADIUS server and is required. If there are no servers in the list, select CREATE and enter the following:
        • LABEL — name of the server
        • TIMEOUT — Not applicable for primary RADIUS server. For the secondary RADIUS server, it indicates the timeout for switching back to the primary RADIUS server after failover.
        • SECRET — the shared secret used for encryption when a client connected to the device’s AP is connecting to the RADIUS authentication server
      • Optionally select the RADIUS AUTHENTICATION SERVER 2 to specify the backup RADIUS server. Select from the list, or select CREATE.
      • Disabled
    • Enable AUTO CHANNEL to have the router choose the channel on which to operate.
      To use a specific channel, disable AUTO CHANNEL and then select a channel from the CHANNEL list that appears.
      The AP and corresponding Client interface (2.4GHz or 5GHz) share a radio and therefore share the same operating channel. If both 2.4GHz AP and Client are enabled, or 5GHz AP and Client are enabled, when the Client interface connects to a remote access point, the XR80’s AP interface switches channels to match the channel that the Client is using.
      When the Client disconnects from the remote AP, the radio stays disconnected for 5 scans and then the XR80’s AP switches back to its original setting (AUTO CHANNEL or selected CHANNEL).
      Ensure that DFS Channels are enabled whenever the 5GHz Access Point is used. Enabling DFS Channels enhances Client interface connectivity and ensures proper Access Point interface channel operation when in the presence of radar. See Configuring the Wi-Fi Radios above.
    • Enable AUTO BEACON INTERVAL to have the router send periodic messages (beacons) to advertise its availability. To choose a specific interval, disable AUTO BEACON INTERVAL and then manually enter the required BEACON INTERVAL in milliseconds (100 ms is the default).
    • When CLIENT ISOLATION is disabled (the default setting), clients can “see” each other, and potentially sniff traffic from each other. * For passenger Wi-Fi applications, enable client isolation to enhance security. * Disable client isolation if you have client applications on the same LAN segment that need to interact with each other.
    • Set the MAX NUMBER OF CLIENTS — Enter the maximum number of clients that can connect simultaneously to this access point interface. As a guideline, set a limit that is slightly higher than the number of clients you expect to connect.
      • Wi-Fi AP 5GHz supports up to 128 clients (includes clients connected to up to two additional 5GHz SSIDs)
      • Wi-Fi AP 2.4GHz supports up to 128 clients (includes clients connected to up to two additional 2.4GHz SSIDs)
      For example (using the 5GHz radio in the figure below, which is capable of supporting up to 128 clients):
      Configured Maximum Total Allowed Wi-Fi AP 5GHz connected Wi-Fi 5GHz SSID 1 connected Wi-Fi 5GHz SSID 2 connected Available
      Wi-Fi A 5GHz = 128
      Wi-Fi 5GHz SSID 1 = 128
      Wi-Fi 5GHz SSID 2 = 128
      128 50 46 0 32 across all three SSIDs
      Wi-Fi A 5GHz = 30
      Wi-Fi 5GHz SSID 1 = 20
      Wi-Fi 5GHz SSID 2 = 10
      60 25 20 5 10 across Wi-Fi A 5GHz and Wi-Fi 5GHz SSID 2
      (Wi-Fi 5GHz SSID 1 is at max.)
      • Disabled (default)
    • Set MSS — When MSS CLAMPING is set to Manual, set the Maximum TCP Segment Size.
    Adding Additional SSIDs (Virtual Access Points)
    Up to two additional SSIDs can be enabled for each of the access point interfaces (i.e., two for Wi-Fi AP 5GHz and two for Wi-Fi AP 2.4GHz).
    To configure an additional SSID, click at the end of the row in the ADDITIONAL SSIDS table (as shown above).
    To configure this feature:
    Configuring Wi-Fi Client Mode
    To use a scanned SSID:
    1. In the SCANNED SSIDS table, click SELECT to add the desired SSID to the SELECTED SSIDS table. You must then fully enable the new SSID by adding the SSID’s security passphrase.
    2. In the SELECTED SSIDS table, click edit for the desired Client SSID.
    4. Click UPDATE.
    To create an SSID manually:
    4. For all security modes except OPEN and WPA2-Enterprise, enter a SECURITY PASSPHRASE of at least 8 characters.
          • USER PASSWORD
            SETTING DESCRIPTION
            TYPE Root Certificate
          • A USER CERTIFICATE WITH A ROOT CERTIFICATE. Select a certificate from the Uploaded certificates list or the Generated certificates list. If the certificate is not present, click CREATE and enter the following:
            SETTING DESCRIPTION
            TYPE Certificate
    5. Select CREATE.
    • ENABLE the interface, and leave the MODE as Client.
    • Set the BACKGROUND SCAN switch, which enables or disables the router scanning and connecting to higher priority SSIDs while already connected.
    • Enter the BACKGROUND SCAN INTERVAL, which sets how often the router scans for other SSIDs when connected.
