Odometer is not a standard OBD-II data point. On heavy duty vehicles and some selected light duty vehicles, it can be read from the CAN bus. However when it is not available, it can be derived from speed and distrance travelled. Setting the derived odometer configures the starting point from which to calculate further distance from.
| REPORT MODE |
| GENERATE THIS REPORT AT POWER ON | Report that will be generated when the device powers on. Note: Only one report can be selected. |
| GENERATE THIS REPORT AT POWER OFF | Report that will be generated when the device powers off. Note: Only one report can be selected and in situations where there is an abrupt power disconnect a report may not be generated. |
| GENERATE THIS REPORT… | List of reports that have been defined. nly one report can be selected. |
| EVERY …(SECONDS) | Number of seconds between each report interval |
| ENABLE | When enabled, the configured report will be generated at each data sample. Default is On. ptions are On/Off. |
| AT EVERY SAMPLE OF… |
Example 2 : WAN Ready
No sample is generated because the WAN connectivity for the device is still UP through Cellular.
Example 3 : Ignition Status
Example 4 : Primary WAN
Options are:
Options are:
| <RELATIONAL OPERATOR> |
Options are
Example : LEVEL Trigger
Options are:
Options are
Example : EDGE Trigger
| ENABLE | Enables vehicle behavior reports | On/Off | On |
| REPORT MODE | Destination of where reports will be sent to. The MQTT configuration will only display if the REPORT MODE is set to an MQTT option. |
ALMS |
| EXCESSIVE ACCELERATION THRESHOLD(MILLIG) | Maximum acceleration allowed before notification is triggered | 100 to 1000 | 250 |
| EXCESSIVE ACCELERATION QUALIFICATION TIME | Length of time in milliseconds, over which acceleration data is collected and analyzed to determine whether an excessive acceleration event has occurred | 250 to 1000 | 500 |
| EXCESSIVE BRAKING THRESHOLD(MILLIG) | Maximum braking allowed before notification is triggered | 100 to 1000 | 350 |
| EXCESSIVE BRAKING QUALIFICATION TIME | Length of time in milliseconds, over which braking data is collected and analyzed to determine whether an excessive braking event has occurred | 250 to 1000 | 500 |
| EXCESSIVE CORNERING THRESHOLD(MILLIG) | Maximum cornering allowed before notification is triggered | 100 to 1000 | 350 |
| EXCESSIVE CORNERING QUALIFICATION TIME | Length of time in milliseconds, over which cornering data is collected and analyzed to determine whether an excessive cornering event has occurred | 250 to 1000 | 500 |
| SUM THRESHOLD(MILLIG) | Vector sum of 3 dimensions(forward/backward, left/right, up/down) | 100 to 2000 | 800 |
| SUM QUALIFICATION TIME | Amount of time that harsh movement was detected. In milliseconds | 250 to 1000 | 250 |
| CLIENT ID | Unique vehicle id | N/A | |
None |
| TOPIC |
6Q1099009902AC24/test {
“atp.ser” :
“t”: 1693258321.3640001,
“v” : “6Q1099009902AC24”
“ts” : 1693268920.464
0 : At most one-time delivery. Your data can be lost. No retransmission outside of TCP. |
0 |
ATP FORMAT |
Individual Timestamp |
