Telemetry data collection requires the router to be properly installed and connected to the vehicle. For most applications, you must connect the router’s ignition line (white wire on the power connector) to the vehicle ignition, and connect the router to the vehicle bus as described in the XR Series Hardware User Guide.
Vehicle settings are a subset of telemetry. To collect vehicle ignition status and CAN bus data from the connected vehicle, configure:
| VIN FORMAT |
VIN FORMAT specifies how the router decodes the vehicle’s VIN (Vehicle Identification Number) to determine the vehicle’s Make, Model and Year for matching against configured proprietary message descriptors. The router can only decode VINs in North American format. This setting prevents false matches when the router is connected to a non-North American vehicle. When set to North American, the router decodes the VIN and matches the resulting Make, Model and Year against proprietary message descriptors to retrieve proprietary data points from the vehicle. When set to Other, the router does not decode or match the VIN. |
North American, Other | North American |
To view the status of your telemetry configuration, go to Status > Services > Telemetry.
J1939 and J1979 protocols are currently supported. J1979-2 is supported in Beta mode, as shown below. Semtech is investigating support for J1979-3 and VDV 238 protocols.
Features marked “Beta” are available for early evaluation. While functional, they may be refined based on field feedback before general release. Please send feedback to trialfeedback@sierrawireless.com
The complete telemetry data set can be sent to AirVantage allowing for the viewing of all Advanced Mobility Reports (AMR). For more information, see Enabling Reporting in AirLink OS.
| REPORT MODE |
Report that will be generated when the device powers off. Note: Only one report can be selected, and in situations where there is an abrupt power disconnect a report may not be generated. |
| AT EVERY SAMPLE OF… |
GPIO Input Cumulative is calculated using the following:
Example 2: WAN Ready
No sample is generated because the WAN connectivity for the device is still UP through Cellular.
Example 3: Ignition Status
Example 4: Primary WAN
Options are:
Options are:
| <RELATIONAL OPERATOR> |
Options are:
Example : LEVEL Trigger
Options are:
Options are:
Example: EDGE Trigger
| ENABLE | Enables vehicle behavior reports | On/Off | On |
| REPORT MODE | Destination of where reports will be sent to. The MQTT configuration will only display if the REPORT MODE is set to an MQTT option. |
ALMS |
| EXCESSIVE ACCELERATION THRESHOLD(MILLIG) | Maximum acceleration allowed before notification is triggered | 100 to 1000 | 250 |
| EXCESSIVE ACCELERATION QUALIFICATION TIME | Length of time, in milliseconds, over which acceleration data is collected and analyzed to determine whether an excessive acceleration event has occurred | 250 to 1000 | 500 |
| EXCESSIVE BRAKING THRESHOLD(MILLIG) | Maximum braking allowed before notification is triggered | 100 to 1000 | 350 |
| EXCESSIVE BRAKING QUALIFICATION TIME | Length of time, in milliseconds, over which braking data is collected and analyzed to determine whether an excessive braking event has occurred | 250 to 1000 | 500 |
| EXCESSIVE CORNERING THRESHOLD(MILLIG) | Maximum cornering allowed before notification is triggered | 100 to 1000 | 350 |
| EXCESSIVE CORNERING QUALIFICATION TIME | Length of time, in milliseconds, over which cornering data is collected and analyzed to determine whether an excessive cornering event has occurred | 250 to 1000 | 500 |
| SUM THRESHOLD(MILLIG) | Vector sum of 3 dimensions (forward/backward, left/right, up/down) | 100 to 2000 | 800 |
| SUM QUALIFICATION TIME | Amount of time, in milliseconds, that harsh movement was detected. | 250 to 1000 | 250 |
The MQTT section appears only when a custom report or a vehicle behavior report has the REPORT MODE set to an MQTT option.
N/A | N/A |
None |
| TOPIC |
6Q1099009902AC24/test {
“atp.ser” :
“t”: 1693258321.3640001,
“v” : “6Q1099009902AC24”
“ts” : 1693268920.464
0 |
ATP FORMAT |
Individual Timestamp |
| CONNECTION SECURITY |
None |
| ROOT CERTIFICATE |
N/A |
