The AirLink XR90 has five Ethernet ports. These are labeled 1 to 3 on the main chassis and XP1 and XP1 on the two cartridges. By default, all Ethernet ports are configured as LAN interfaces; however, it is possible to configure ports as WAN interfaces (see below).
You cannot configure static IP for an Ethernet WAN interface in AirLink OS version 2.0. The WAN IP address can only be assigned by a DHCP server.
5000baseT/Full and 2500baseT/Full are only for Ethernet 1 (5G). Although you can select these modes for other Ethernet interfaces, AirLink OS notifies you of a configuration error after saving.
To enable an Ethernet interface for WAN:
On the row for the desired Ethernet port, click X to clear the default Bridge setting.
Click SAVE. The Bridge for that interface is now blank.
Check Networking > Zones Settings > Zones. The Ethernet port is now in the WAN zone.
Connect a WAN source to the newly configured Ethernet port.
Confirm the configuration in the Status/Monitoring dashboard. The configured Ethernet port should appear as a WAN interface.
