SETTING | DESCRIPTION | OPTIONS | DEFAULT |
SERVICE | Configure telemetry service to be enabled or disabled | On/Off | Off |
CLEAR TELEMETRY DATA AT NEXT REBOOT | Erases all telemetry data at next reboot | Off/Pending | Off |
PERSIST TELEMETRY DATA NOW | Saves telemetry data to flash storage. This is also automatically done at shutdown | Off/Pending | Off |
TELEMETRY DATA LAST CLEARED AT | Shows the date and time that all telemetry data was last cleared. Read only. | N/A | N/A |
TELEMETRY DATA LAST SAVED AT | Shows the date and time that all telemetry data was last saved. Read only. | N/A | N/A |
DATA COLLECTION | Enables or disables data collection | On/Off | On |
MODE OF OPERATION | Configures when data collection will be active |
VEHICLE IGNITION WIRING | This setting determines which input line the router monitors for ignition status. Select the option that matches how the vehicle ignition line has been connected to the router. |
VEHICLE IGNITION STATUS | Current vehicle ignition status. Read only. | On/Off | N/A |
Odometer is not a standard OBD-II data point. On heavy duty vehicles and some selected light duty vehicles, it can be read from the CANBUS. However when it is not available, it can be derived from speed and distrance travelled. Setting the derived odometer configures the starting point from which to calculate further distance from.
SETTING | DESCRIPTION | RANGE | DEFAULT |
SET DERIVED ODOMETER (KM) | Sets the derived odometer with a starting value from which to calculate further distance from. | 0 to 1000000 | 0 |
ENTERED AT | Date and time that the SET DERIVED ODOMETER was updated. Read only. | N/A | N/A |
CURRENT ODOMETER (KM) | Current physical odometer reading. Read only. | N/A | N/A |
CURRENT ODOMETER TIMESTAMP | Date and time that the CURRENT ODOMETER was read. Read only. | N/A | N/A |
ENABLE | When enabled, the full telemetry data set is sent to AirVantage so that all Advanced Mobility Reports (AMR) can be viewed. Only displays when Telemetry is enabled. | On/Off | On |
REPORT TITLE | Name of the report used to reference this report in the trigger definitions section. Report Title is not sent as part of the report. |
REPORT MODE |
MQTT TOPIC REPORT NAME | Name of the report that will be included in the MQTT TOPIC. |
REPORT CONTENT | List of all telemetry data points that will be used to generate a report. It is possible to select more than one of these data points for each report. |
GENERATE THIS REPORT AT POWER ON | Report that will be generated when the device powers on. Note: Only one report can be selected. |
GENERATE THIS REPORT AT POWER OFF | Report that will be generated when the device powers off. Note: Only one report can be selected and in situations where there is an abrupt power disconnect a report may not be generated. |
ENABLE | When enabled, the configured report will be generated at each configured interval. Default is On. Options are On/Off. |
GENERATE THIS REPORT… | List of reports that have been defined. Only one report can be selected. |
EVERY …(SECONDS) | Number of seconds between each report interval |
ENABLE | When enabled, the configured report will be generated at each data sample. Default is On. Options are On/Off. |
AT EVERY SAMPLE OF… |
When the data item sampled has changed from the last sample, the configured report will be generated. Options are
Example 2 : WAN Ready
Example 3 : Ignition Status
Example 4 : Primary WAN
ENABLE | When enabled, the configured report will be generated when the sampled value has changed at least the configured amount since the last sample or a configured maximum time has passed. Default is On. Options are On/Off. |
WHEN THIS ITEM’S SAMPLED VALUES… |
Options are
CHANGE BY THIS AMOUNT SINCE LAST REPORT… | Range from 0 to 1000000 |
OR THIS TIME ELAPSES SINCE LAST REPORT (OPTIONAL - SECONDS)… | Range from 1 to 3000000 |
ENABLE | When enabled, the configured report will be generated when the configured condition is true. Default is On. Options are On/Off. |
WHILE THIS ITEM’S SAMPLED VALUES ARE… |
Options are
<RELATIONAL OPERATOR> |
Options are
THIS THRESHOLD VALUE | Range from -1000000 to 1000000 |
Example : LEVEL Trigger
WHEN THIS ITEM’S SAMPLED VALUES BECOMES |
Options are:
Options are
Example : EDGE Trigger
ENABLE | Enables vehicle behavior reports | On/Off | On |
REPORT MODE | Destination of where reports will be sent to. The MQTT configuration will only display if the REPORT MODE is set to an MQTT option. |
ALMS |
EXCESSIVE ACCELERATION THRESHOLD(MILLIG) | Maximum acceleration allowed before notification is triggered | 100 to 1000 | 250 |
EXCESSIVE ACCELERATION QUALIFICATION TIME | Length of time in milliseconds, over which acceleration data is collected and analyzed to determine whether an excessive acceleration event has occurred | 250 to 1000 | 500 |
EXCESSIVE BRAKING THRESHOLD(MILLIG) | Maximum braking allowed before notification is triggered | 100 to 1000 | 350 |
EXCESSIVE BRAKING QUALIFICATION TIME | Length of time in milliseconds, over which braking data is collected and analyzed to determine whether an excessive braking event has occurred | 250 to 1000 | 500 |
EXCESSIVE CORNERING THRESHOLD(MILLIG) | Maximum cornering allowed before notification is triggered | 100 to 1000 | 350 |
EXCESSIVE CORNERING QUALIFICATION TIME | Length of time in milliseconds, over which cornering data is collected and analyzed to determine whether an excessive cornering event has occurred | 250 to 1000 | 500 |
SUM THRESHOLD(MILLIG) | Vector sum of 3 dimensions(forward/backward, left/right, up/down) | 100 to 2000 | 800 |
SUM QUALIFICATION TIME | Amount of time that harsh movement was detected. In milliseconds | 250 to 1000 | 250 |
BROKER HOSTNAME | Hostname of MQTT broker | IPV4 | localhost |
PORT | Port that the MQTT broker is listening for incoming connections | Default port normally used is 1883. See your MQTT broker administrator. | N/A |
CLIENT ID | Unique vehicle id | N/A | |
AUTHENTICATION | Authentication information used to connect to MQTT broker |
None |
TOPIC |
Used to identify the subject of a message. 6Q1099009902AC24/test { “atp.ser” : { “t”: 1693258321.3640001, “v” : “6Q1099009902AC24” }, “ts” : 1693268920.464 } |
QOS LEVEL | Quality of Service level |
0 : At most one-time delivery. Your data can be lost. No retransmission outside of TCP. |
0 |
KEEPALIVE PERIOD | Maximum time that can elapse between two messages | 0 to 3600 s | 1 MIN |
TX REPORT BURST | Maximum number of reports to send before rate limiting | 0 to 1000 | 0 |
TX REPORT RATE [REPORTS/MINUTE] | Maximum number of reports to send per minute | 0 to 6000 | 0 |
ACKNOWLEDGE TIME | Time to wait for acknowledgement | 1 to 600 s | 10 s |
MAX PENDING REPORTS | Maximum number of pending reports before it will start to purge the oldest | 100 to 100000 | 100 |
DATA FORMAT | Format of data sent to MQTT broker. |
ATP FORMAT |
TIMESTAMP FORMAT | Format of timestamp used in report sent to MQTT broker. |
Individual Timestamp |
