    Configuring Wi-Fi
    This page shows you how to configure Wi-Fi for your AirLink XR90 router in Access Point mode and Client mode.
    Wi-Fi Interfaces
    WI-FI INTERFACE MODE ANTENNA BANK
    Wi-Fi A 5GHz
    Access Point (Default)
    Can be configured for Client mode.
    Always uses Antenna Bank A (i.e. “Wi-Fi A” connectors).
    Wi-Fi AP 2.4GHz Access Point (Default)
    Uses Antenna Bank A or B. (A — “Wi-Fi A”, B — “Wi-Fi B”)
    Select the Antenna Bank that is most suitable for your client devices.
    Wi-Fi B 5GHz
    Client (Default)
    Can be configured for Access Point mode.
    Always uses Antenna Bank B (i.e. “Wi-Fi B” connectors).
    Wi-Fi Client 2.4GHz Client (Default) Uses Antenna Bank A or B. (A — “Wi-Fi A”, B — “Wi-Fi B”)
    REGION
    The REGION field is the regulatory domain that the router Wi-Fi is using. It is determined by using either the Global Navigation Satellite System (GNSS) sensors in the router, or by the Mobile Country Code (MCC) or Mobile Network Code (MNC) received from the carrier and received directly by the receiver on the device. The router automatically loads the operating frequencies for that regulatory region on each Wi-Fi radio interface in the software and enables 802.11d for broadcasting the newly obtained country information. If the router is not able to determine the region, it uses a default region setting. For more information on supported channels, please refer to the Wi-Fi specifications in the AirLink XR80/XR90 Hardware User Guide .
    PLACEMENT
    • When Indoor is selected, the router can use only the channels allowed for indoor use.
    For more information on supported channels, refer to the Wi-Fi specifications in the AirLink XR80/XR90 Hardware User Guide .
    If the AirLink router cannot determine the region, the default region setting for that router variant determines whether the PLACEMENT switch appears.
    For example, if an AirLink router EMEA variant cannot determine the region, the REGION appears as “Unknown (restricted)” and the PLACEMENT switch appears, with Indoor as the default.
    NOTES:
    • Enabling DFS Channels will make DFS-specific channels available to both AP and Client mode regardless of the region and, if applicable, PLACEMENT option.
    For details on how your router is determining its region, go to Status/Monitoring > Services > Geolocation.
    Configuring Wi-Fi Radios
    • In the Physical field, select the network standard to use.
      • 2.4GHz Access Point configuration: In general, select b/g/n/ax, which also uses the latest standard (11ax), and supports legacy compatibility for 11b, 11g, and 11n. b and b/g/n are the other options available.
      • 5GHz Access Point configuration: In general, select n/ac/ax, which uses the latest standard (11ax), and supports legacy compatibility for 11n and 11ac. Typically, only select n/ac for testing any legacy compatibility issues.
    • In the Channel Bandwidth field, select the bandwidth to use (up to 80 MHz). Each 20 MHz of bandwidth corresponds to 1 channel (i.e., 1 channel = 20 MHz, 4 channels = 80 MHz).
    • Select the MIMO (Multiple Input/Multiple Output) configuration for your installation to optimize throughput and signal quality. Each Wi-Fi antenna bank can have up to 4 antennas connected. Select a non-default setting for an access point if you discovered problems with legacy equipment, have fewer than the maximum number of antennas connected, or to improve the XR90’s thermal performance.
      • 4x4 enables all four antennas for sending and receiving traffic
      • 2x4 configures two antennas for sending and four for receiving
    • Enable DFS Channels to open up more Wi-Fi channels for the router to use, while preventing the router interfering with channels used by radar equipment (near airports, for example). With DFS Channels enabled, the router will switch channels if it detects radar equipment using the same channel. Unless you know that your other operating equipment is DFS capable, Sierra Wireless recommends leaving DFS Channels disabled.
      • Enabling DFS allows for more 5GHz channels, but may result in delayed connectivity at boot and in the presence of radar.
      • The DFS Channels setting applies to both AP and Client mode. In Client mode, the router will only be able to connect using the available channels.
    • The Transmit Power Level setting allows you to restrict transmit power to the Wi-Fi antenna(s). The actual transmit power attained depends on a number of factors including the regulatory domain and the wireless channel used. Generally, a higher transmit power setting results in greater Wi-Fi range for the clients. Set for 100% by default, and adjust for network conditions. If clients are connecting with many other clients nearby, high transmit power can cause interference and impede throughput across connected clients.
    To configure an interface as an Access Point, click at the end of an Access Point interface row in the WI-FI INTERFACES table (as shown above).
    • ENABLE the interface, and leave the MODE as Access Point.
    • If an ANTENNA BANK choice is shown, select the bank that is most suitable for your client devices:
      • A — Wi-Fi A
      • B — Wi-Fi B
      Best Practice recommendation: If the 2.4GHz and 5GHz AP(s) are configured on different LAN segments, use different SSIDs and security passphrases to make sure DHCP renews IP addresses when switching between the APs.
      • WPA — Requires only a SECURITY PASSPHRASE (This mode is not recommended and will only be seen if the LEGACY MODE is enabled.)
      • Select the RADIUS AUTHENTICATION SERVER to use. This is the primary RADIUS server and is required. If there are no servers in the list, select CREATE and enter the following:
        • LABEL — name of the server
        • TIMEOUT — the time limit for the server to respond. If the server does not respond during the timeout, the authentication fails and the other RADIUS AUTHENTICATION SERVER (if configured) checks the credentials.
        • SECRET — the shared secret used for encryption when a client connected to the device’s AP is connecting to the RADIUS authentication server
      • Optionally select the RADIUS AUTHENTICATION SERVER 2 to specify the backup RADIUS server. Select from the list, or select CREATE.
      • Disabled
    • Enable AUTO CHANNEL to have the router choose the channel on which to operate.
    • Enable AUTO BEACON INTERVAL to have the router send periodic messages (beacons) to advertise its availability. To choose a specific interval, disable AUTO BEACON INTERVAL and then manually enter the required BEACON INTERVAL in milliseconds (100 ms is the default).
      For example, if the DTIM Period is set to 3, the client sleeps through two beacons and wakes for the third beacon. The higher the DTIM PERIOD value, the longer the client device can sleep, and the more battery power the client device can potentially save. However, high DTIM periods can also reduce throughput to the client. The default period is 2 (wake for every second beacon).
      • For passenger Wi-Fi applications, enable client isolation to enhance security.
      • Disable client isolation if you have client applications on the same LAN segment that need to interact with each other.
    • Set the MAX NUMBER OF CLIENTS — Enter the maximum number of clients that can connect simultaneously to this access point interface. As a guideline, set a limit that is slightly higher than the number of clients you expect to connect.
      • Wi-Fi A 5GHz in AP mode supports up to 128 clients (includes clients connected to up to two additional 5GHz SSIDs)
      • Wi-Fi AP 2.4GHz supports up to 64 clients (includes clients connected to up to two additional 2.4GHz SSIDs)
      • Wi-Fi B 5GHz in AP mode supports 64 clients (includes clients connected to up to two additional 5GHz SSIDs)
      For example (using the Wi-Fi A 5GHz radio in the figure below, which is capable of supporting up to 128 clients):
      Configured Maximum Total Allowed Wi-Fi A 5GHz connected Wi-Fi A 5GHz SSID 1 connected Wi-Fi A 5GHz SSID 2 connected Available
      Wi-Fi A 5GHz = 128
      Wi-Fi A 5GHz SSID 1 = 128
      Wi-Fi A 5GHz SSID 2 = 128
      128 50 46 0 32 across all three SSIDs
      Wi-Fi A 5GHz = 30
      Wi-Fi A 5GHz SSID 1 = 20
      Wi-Fi A 5GHz SSID 2 = 10
      60 25 20 5 10 across Wi-Fi A 5GHz and Wi-Fi A 5GHz SSID 2
      (Wi-Fi 5GHz A SSID 1 is at max.)
    • Select the MSS CLAMPING option — MSS (Maximum TCP Segment Size) Clamping controls the maximum packet size used for TCP connections between a local (LAN-side) host and a remote host over the Wi-Fi WAN interface. MSS Clamping helps avoid possible issues with sending and receiving large TCP packets over the WAN interface when other standard MTU mechanisms do not appear to be working with your installation. The options are:
      • Disabled (default)
      • Manual — MSS is clamped to the specified maximum value bidirectionally for all inbound (remote-to-LAN) and outbound (LAN-to-remote) TCP connections when the TCP session is established using the Wi-Fi interface.
    • Set MSS — When MSS CLAMPING is set to Manual, set the Maximum TCP Segment Size.
    Adding Additional SSIDs (Virtual Access Points)
    Up to two additional SSIDs can be enabled for each of the access point interfaces (i.e., two for Wi-Fi A 5GHz, two for Wi-Fi AP 2.4GHz, and two for Wi-Fi B 5GHz).
    To configure an additional SSID, click at the end of the row in the ADDITIONAL SSIDS table (as shown above).
    To configure this feature:
    Configuring Wi-Fi Client Mode
    Tip: Hover the pointer on a scanned SSID to view the channel, BSSID and RSSI for each band.
    To use a scanned SSID:
    1. In the SCANNED SSIDS table, click SELECT to add the desired SSID to the SELECTED SSIDS table. You must then fully enable the new SSID by adding the SSID’s security passphrase.
    2. In the SELECTED SSIDS table, click edit for the desired Client SSID.
    4. Click UPDATE.
    To create an SSID manually:
    4. For all security modes except OPEN and WPA2-Enterprise, enter a SECURITY PASSPHRASE of at least 8 characters.
          • USER PASSWORD
            SETTING DESCRIPTION
            TYPE Root Certificate
            SETTING DESCRIPTION
            TYPE Certificate
    5. Select CREATE.
    • ENABLE the interface, and leave the MODE as Client.
    • Set the BACKGROUND SCAN switch, which enables or disables the router scanning and connecting to higher priority SSIDs while already connected.
    • Enter the BACKGROUND SCAN INTERVAL, which sets how often the router scans for other SSIDs when connected.
    Additionally, you can go to Status/Monitoring > System > Wi-Fi to view detailed Wi-Fi Client status, including bit rate and the active channel.
