AirLink XR80 and XR90 routers, with their vehicle telemetry capability and inertial sensors, will support all features of AMR.
As well, ensure that the ignition SHUTDOWN DELAY is set to at least 30 seconds (the default setting is 3 seconds).
Under Services > Telemetry > Vehicle:
Under Services > Telemetry > AMR Reports, enable AMR Reports.
Under MCU > Power Management, configure the ignition SHUTDOWN DELAY to be at least 30 seconds.
