WP76xx Firmware Release 10.1.1.1
  • Sep 7, 2022
  • Version: 3.0
This page describes the procedure to update WP76xx with Firmware Release 10.1.1.1
WP76xx firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 10.1.1.1 Updates, below.
  • As separate components for developers that wish to build custom Linux Distribution or Base Legato System images. See WP76xx Firmware Release 10.1.1.1 Components to create custom firmware packages.
         R10.1.1.1 (Generic) — WP7601, WP7603, WP7607, WP7608, WP7609, WP7610
         R10.1.1.1 (AT&T) — WP7603
         R10.1.1.1 (Verizon) — WP7601
         R10.1.1.1 (Sierra Wireless) — WP7601, WP7603, WP7607, WP7608, WP7609, WP7610
    Legato for WP76 R10.1 (18.6.3.wp76xx-docker-201810311826) for Windows
    or
    Legato for WP76 R10.1 (18.6.3.wp76xx-native-x86_64-201810311828) for Linux
For details about this firmware release, refer to the WP76xx Release 10.1.1.1 Customer Release Notes.
Generic
SWI9X07Y_02.18.05.00 / 002.041_004
002.009
SWI9X07Y_02.18.07.01
18.06.3
AT&T SWI9X07Y_02.18.05.00 / 002.040_003 002.009 SWI9X07Y_02.18.07.01 18.06.3
Verizon SWI9X07Y_02.18.05.00 / 002.041_003 002.009 SWI9X07Y_02.18.07.01 18.06.3
Sierra Wireless SWI9X07Y_02.18.05.00 / 001.002_003 002.009 SWI9X07Y_02.18.07.01 18.06.3
WP76xx Firmware Release 10.1.1.1 | Source
