WP76xx Firmware Release 13.0.1
  • May 27, 2022
  • Version: 2.0
This page describes the procedure to update WP76xx with Firmware Release 13.0.1
WP76xx firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 13.0.1 Updates, below.
  • As separate components for developers that wish to build custom Linux Distribution or Base Legato System images. See WP76xx Firmware Release 13.0.1 Components to create custom firmware packages.
(Windows) 'One-click' tool
         R13.0.1 (Generic — PTCRB) — WP7603, WP7610
         R13.0.1 (Generic — GCF) — WP7603, WP7610
R13.0.1 (AT&T) — WP7603, WP7610
(Linux) Legato CLI
Developer Studio
    Legato for WP76 R13 (19.2.0.wp76xx-docker-201906171318) for Windows
    or
    Legato for WP76 R13 (19.2.0.wp76xx-native-x86_64-201906171319) for Linux
(Linux QMI SDK)
2. Follow instructions from the user guide:
    Linux QMI SDK Application Developer's Guide
For details about this firmware release, refer to the WP76xx Release 13.0.1 Customer Release Notes.
Generic — PTCRB SWI9X07Y_02.28.03.01 / 002.064_003 002.011 SWI9X07Y_02.28.07.02
19.02.0
Generic —GCF SWI9X07Y_02.28.03.01 / 002.064_003 002.011
SWI9X07Y_02.28.07.02 19.02.0
AT&T SWI9X07Y_02.28.03.01 / 002.071_007 002.011 SWI9X07Y_02.28.07.02
19.02.0
WP76xx Firmware Release 13.0.1 | Source
