WP76xx Firmware Release 16.1
- Sep 7, 2022
- Version: 2.0
This page describes the procedure to update WP76xx with Firmware Release 16.1
WP76xx firmware is available:
- As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 16.1 Updates, below.
See WP76xx Firmware Release 16.1 Components to create custom firmware packages.
1. If not already done, download the latest USB driver and launch the executable.
3. Connect the target's (e.g mangOH) USB cable to your host |
| MBPL (Linux) |
2. Follow instructions from the Software Integration and Development Guide for Linux USB Platforms included in the MBPL (Mobile Broadband Package for Linux). |
| Leaf Workspace Manager |
For details about this firmware release, refer to the WP76xx Release 16.1 Customer Release Notes.
| Carrier Approval |
| Generic — GCF and PTCRB |
SWI9X07Y_02.37.03.05 / 002.115_002 | 002.015 |
SWI9X07Y_02.37.10.02 | 19.11.6 |
| AT&T | SWI9X07Y_02.37.03.05 / 002.126_000 | 002.015 | SWI9X07Y_02.37.10.02 | 19.11.6 |
| T-Mobile (TMO) | SWI9X07Y_02.35.02.00 / 001.017_001 | 002.015 | SWI9X07Y_02.37.10.02 | 19.11.6 |
| Verizon | SWI9X07Y_02.37.06.00 / 002.107_003 | 002.015 | SWI9X07Y_02.37.10.02 | 19.11.6 |
| DOCOMO | SWI9X07Y_02.28.03.05 / 001.024_001 | 002.015 | SWI9X07Y_02.37.10.02 | 19.11.6 |
| KDDI | SWI9X07Y_02.28.03.05 / 001.026_002 | 002.015 | SWI9X07Y_02.37.10.02 | 19.11.6 |
| LGU | SWI9X07Y_02.32.03.01 / 001.026_001 | 002.015 | SWI9X07Y_02.37.10.02 | 19.11.6 |
| SoftBank | SWI9X07Y_02.28.03.05 / 001.028_001 | 002.015 | SWI9X07Y_02.37.10.02 | 19.11.6 |
| Telstra | SWI9X07Y_02.28.03.05 / 001.058_001 | 002.015 | SWI9X07Y_02.37.10.02 | 19.11.6 |
