WP76xx Firmware Release 17
Jun 15, 2023 - Author: Sierra Wireless - Version 1 - 15158 Views
WP76xx Release 17 is a major milestone release with upgrades to Linux Kernel 4.14 and Yocto LTS 3.1. This release also comes with crucial improvements for security vulnerabilities.
WP76xx firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 17 Updates, below.
    See WP76xx Firmware Release 17 Components to create custom firmware packages.
Important note for the 2-stage AV FOTA firmware upgrade:
  • All legacy firmware releases can only be upgraded by AV FOTA to Firmware Release 17 via Firmware 16.3. The AV FOTA process to intermediate Firmware Release 16.3 must firstly be completed before proceeding to the AV FOTA process of upgrading to Firmware Release 17.
  • No firmware downgrade back to prior firmware releases is allowed once the firmware is upgraded to Release 17.
'One-click' tool
         R17 (DOCOMO) — WP7605
         R17 (SoftBank) — WP7605
         R17 (KDDI) — WP7605
         R17 (Generic — GCF) — WP7607, WP7607-1, WP7608, WP7608-1, WP7609
         R17 (Generic — PTCRB) — WP7611, WP7611-1
         R17 (Telstra) — WP7609
         R17 (LGU) — WP7609
         R17 (AT&T) — WP7611, WP7611-1
         R17 (Verizon) — WP7611, WP7611-1
         R17 (T-Mobile) — WP7611, WP7611-1
MBPL (Linux)
         R17 (KDDI) — WP7605
         R17 (LGU) — WP7609
Leaf Workspace Manager
For details about this firmware release, refer to the WP76xx Release 17 Customer Release Notes.
Generic — GCF and PTCRB
SWI9X07Y_02.37.06.05 / 002.128_000 002.015
SWI9X07Y_03.01.07.00 21.05.2
AT&T  SWI9X07Y_02.37.03.05 / 002.130_000 002.015 SWI9X07Y_03.01.07.00 21.05.2
T-Mobile (TMO) SWI9X07Y_02.35.02.00 / 001.017_001 002.015  SWI9X07Y_03.01.07.00  21.05.2
Verizon  SWI9X07Y_02.37.06.05 / 002.123_000 002.015  SWI9X07Y_03.01.07.00  21.05.2
DOCOMO  SWI9X07Y_02.28.03.05 / 001.024_001 002.015  SWI9X07Y_03.01.07.00  21.05.2
KDDI  SWI9X07Y_02.28.03.05 / 001.026_002 002.015  SWI9X07Y_03.01.07.00 21.05.2
LGU  SWI9X07Y_02.32.03.01 / 001.026_002 002.015  SWI9X07Y_03.01.07.00 21.05.2
SoftBank  SWI9X07Y_02.28.03.05 / 001.028_001 002.015  SWI9X07Y_03.01.07.00  21.05.2
Telstra  SWI9X07Y_02.28.03.05 / 001.058_001 002.015  SWI9X07Y_03.01.07.00 21.05.2
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 17 components and how to download it on your product.
This is the WP76xx Release 17 Customer Release Notes download.
©2026 All rights reserved
