WP76xx Firmware Release 17 Components
  • Jun 15, 2023
  • Version: 1
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 17 components and how to download it on your product.
WP76xx Firmware Release 17 combined image
Modem Firmware (Generic — GCF and PTCRB)
SWI9X07Y_02.37.06.05 / 002.128_000
Modem Firmware (AT&T)
SWI9X07Y_02.37.03.05 / 002.130_000
Modem Firmware (T-Mobile)
SWI9X07Y_02.35.02.00 / 001.017_001
Modem Firmware (Verizon)
SWI9X07Y_02.37.06.05 / 002.123_000 Download
Modem Firmware (DOCOMO)
SWI9X07Y_02.28.03.05 / 001.024_001 Download
Modem Firmware (KDDI)
SWI9X07Y_02.28.03.05 / 001.026_002
Modem Firmware (LGU)  SWI9X07Y_02.32.03.01 / 001.026_002 Download  Custom Modem Firmware can NOT be created by customers
Modem Firmware (SoftBank)  SWI9X07Y_02.28.03.05 / 001.028_001   Download  Custom Modem Firmware can NOT be created by customers
Modem Firmware (Telstra)  SWI9X07Y_02.28.03.05 / 001.058_001 Download   Custom Modem Firmware can NOT be created by customers
002.015
SWI9X07Y_03.01.07.00
legato-21.05.2.rc2
 Legato Source Release #
legato-21.05.2.rc2 Source
 R17 (Based on Kernel 4.14 and Yocto 3.1 LTS) SWI9X07Y_03.01.07.00 Source   Open Source Licenses 32-bit ToolChain
  2. Select the "Target Menu".
