WP76xx Firmware Release 17.1
  • Jan 28, 2026
  • Version: 1
This page describes the procedure to update WP76xx with Firmware Release 17.1
WP76xx Release 17.1 is a maintenance release that delivers critical security patches, bug fixes, and stability improvements to enhance system reliability.
WP76xx firmware is available:
  • As pre-built images ready for installation on Windows or Linux hosts. See Installing Firmware Release 17.1 Updates, below.
    See WP76xx Firmware Release 17.1 Components to create custom firmware packages.
Important note for the 2-stage AV FOTA firmware upgrade:
  • All legacy firmware releases can only be upgraded by AV FOTA to the latest version via Firmware 16.3. The AV FOTA process to intermediate Firmware Release 16.3 must firstly be completed before proceeding to the AV FOTA process of upgrading to Firmware Release 17 and later versions such as Firmware Release 17.1.
  • No firmware downgrade back to prior firmware releases is allowed once the firmware is upgraded to Release 17.1.
'One-click' tool
MBPL (Linux)
Leaf Workspace Manager
For details about this firmware release, refer to the WP76xx Release 17.1 Customer Release Notes.
AT&T Data
SWI9X07Y_02.37.06.25 / 001.001_000 002.015
SWI9X07Y_03.01.14.00 21.05.5
AT&T VD SWI9X07Y_02.37.06.25 / 001.003_000 002.015 SWI9X07Y_03.01.14.00 21.05.5
Generic Data SWI9X07Y_02.37.06.25 / 001.002_000  002.015  SWI9X07Y_03.01.14.00  21.05.5
Generic VD  SWI9X07Y_02.37.06.25 / 001.003_000  002.015  SWI9X07Y_03.01.14.00  21.05.5
T-Mobile (TMO) Data SWI9X07Y_02.37.06.25 / 001.000_000 002.015  SWI9X07Y_03.01.14.00  21.05.5
T-Mobile (TMO) VD  SWI9X07Y_02.37.06.25 / 001.000_000  002.015  SWI9X07Y_03.01.14.00   21.05.5
Verizon Data SWI9X07Y_02.37.06.25 / 001.000_000 002.015   SWI9X07Y_03.01.14.00  21.05.5
Verizon VD SWI9X07Y_02.37.06.25 / 001.004_000 002.015  SWI9X07Y_03.01.14.00  21.05.5
DOCOMO  SWI9X07Y_02.28.03.05 / 001.024_001 002.015  SWI9X07Y_03.01.14.00  21.05.5
KDDI  SWI9X07Y_02.28.03.05 / 001.026_002 002.015  SWI9X07Y_03.01.14.00 21.05.5
SoftBank  SWI9X07Y_02.28.03.05 / 001.028_001 002.015  SWI9X07Y_03.01.14.00  21.05.5
