WP76xx Firmware Release 8
  • Mar 1, 2018
  • Version: 8
This page describes the procedure to update WP76xx with Firmware Release 8.
         R8 (Generic — GCF)
         R8 (Generic — PTCRB)
         R8 (AT&T)
         R8 (Verizon)
    Legato for WP76 R8 (18.1.0.wp76xx-docker-201803051401) for Windows
    or
    Legato for WP76 R8 (18.1.0.wp76xx-native-x86_64-201803051402) for Linux
      R8 (Generic — GCF)
      R8 (AT&T)
      R8 (Verizon)
      WP7601 (Generic) Release 8
      WP7601 (Verizon) Release 8
      WP7601-1 (Generic) Release 8
      WP7601-1 (Verizon) Release 8
      WP7603 (ATT) Release 8
      WP7603 (PTCRB) Release 8
      WP7603-1 (ATT) Release 8
      WP7603-1 (PTCRB) Release 8
Consult the WP76xx Release 8 Customer Release Notes
Generic — GCF
SWI9X07Y_02.14.04.00 / 002.025_000
002.007
18.01.0
Generic — PTCRB SWI9X07Y_02.10.01.00 / 002.015_001  002.007 SWI9X07Y_02.14.04.00 18.01.0
AT&T SWI9X07Y_02.10.01.00 / 002.015_001 002.007 SWI9X07Y_02.14.04.00 18.01.0
Verizon SWI9X07Y_02.10.00.00 / 002.014_002 002.007 SWI9X07Y_02.14.04.00 18.01.0
If you build custom Linux Distribution or Base Legato System images for your product, see WP76xx Firmware Release 8 Components to create custom firmware packages.
WP76xx Firmware Release 8 | Source
