(Latest Release) WP7702 Firmware Release 15.2 Components
- Apr 29, 2026
- Version: 4
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 15.2 components and how to download it on your product.
WP7702 Firmware Release 15.2 combined image
| Modem Firmware (Generic) |
SWI9X06Y_02.36.08.14 / 001.082_000 |
002.015 |
SWI9X06Y_03.00.15.03 |
21.05.4 |
Rebuild Linux Distribution and/or Legato from source
| 21.05.4 Source |
SWI9X06Y_03.00.15.03 Source (Based on Kernel 3.18 and Yocto 2.5) |
