WP77xx Firmware Release 12 Components
  • Oct 1, 2019
  • Version: 12
This page describes in detail the components included with the Firmware Release, how to build your own custom device image based on Release 12 components and how to download it on your product.
WP77xx Firmware Release 12 combined image
SWI9X06Y_02.32.02.00 / 001.055_000
SWI9X06Y_02.16.06.00 / 001.028_004
Modem Firmware (AT&T)
SWI9X06Y_02.16.06.00 / 001.026_001
Modem Firmware (Sierra Wireless — GCF)
SWI9X06Y_02.32.02.00 / 001.027_000
Modem Firmware (T-Mobile US)
Modem Firmware (Verizon)
SWI9X06Y_02.22.12.00 / 001.042_001
002.013
19.07.0
19.07.0 Source
SWI9X06Y_02.32.02.00 Source
  2. Select the "Target Menu".
